This issue is entered into our defect database. Unfortunately, it is not
easy to fix. Bill's below recommendation is a possible workaround.
Thank you,
Nicole Dierksheide
From: OSSMANN,BILL (A-hsgAndover,ex1) [mailto:bill_ossmann@hsgmed.com]
Sent: Wednesday, 03 April, 2002 11:47 AM
To: vrf@lvld.agilent.com
Subject: RE: vrf pinging
I just ran a test program and left a dialog box open for about half an hour.
I heard one beep at about 20 minutes, but that was all.
If there are jsut one or two places in your program where this is a problem,
how about putting a timeout on the dialog box? The timeout pin could send
the program into some safe or restartable state. For example, put the dialog
box in an Until Break loop. Use of the dialog box breaks the loop, but the
timeout pin pops up a panel with a message and OK button.
Bill Ossmann
Philips Ultrasound
Sent: Wednesday, April 03, 2002 10:39 AM
Subject: vrf pinging
I have a VEE program that prompts the user to enter the serial number of the
unit they are testing. If the operator does not enter a serial number
within approximately 10 minutes the computer starts to beep e.g. an audible
bell is heard from the computers speaker about once a second.
I didn't put this into the program and was wondering if this is something
automatic with VEE. Has anybody else experienced this ?
Ross
Thank you,
Nicole Dierksheide
Bill Ossmann
Philips Ultrasound
Ross
Bill Ossmann
Philips Ultrasound
Ross
