<!doctype html public "-//w3c//dtd html 4.0 transitional//en"><html>Hello Phil,<p>I used the mechanism described under PeekPoke and it works fine withWindows95, 98, NT and 2K.
In both the latter cases don't forget to install the driver "ppppdrv"with administrator privileges to be started automatically.<p>I include part of an vrf contribution of 2001.<p>Hope this helps<p>Andre Lehmann
IOM GmbH
<A HREF="http://www.iom-berlin.de">http://www.iom-berlin.de</A><blockquote TYPE=CITE><pre>Hi Chris,Explore these links near the bottom of the "VEE Archives" customer postsalessite:<A HREF="http://ftp.agilent.com/pub/mpusup/pc/binfiles/vee/index.html">http://ftp.agilent.com/pub/mpusup/pc/binfiles/vee/index.html</A> "VEE Win95 PEEKPOKE DLL archive." "VEE WinNT (3.51 & 4.0) PEEKPOKE DLL archive (Parallel Port and I/O Port Driver for NT)." Regarding VEE output to printers:The PCL output files I've examined (with showpcl.exe) always start with lotsof PCL setup commands, which may undermine any previous PCL setup commands auser may have output. Showpcl has many entries on <A HREF="http://www.google.com">http://www.google.com</A>Hope this helps!| Ted Cline| IO Support| Basic, Emerging and Systems Technologies (BEST) PGU| Agilent Technologies| CU-326, 815 14th Street SW, P.O. Box 301, Loveland, CO 80537 USA| 800-452-4844 Customer Support (United States)| 877-894-4414 Customer Support (Canada)| 970-679-5260 FAX| ted_cline@agilent.com| io_support@agilent.com| <A HREF="http://ftp.agilent.com/pub/mpusup/index.html">http://ftp.agilent.com/pub/mpusup/index.html</A> Postsales SupportIO Libraries: <A HREF="http://www.agilent.com/find/iolib">http://www.agilent.com/find/iolib</A> <A HREF="http://www.agilent.com/find/iolibux">http://www.agilent.com/find/iolibux</A>VEE: <A HREF="http://www.agilent.com/find/vee">http://www.agilent.com/find/vee</A>BASIC for Windows: <A HREF="http://www.agilent.com/find/basic">http://www.agilent.com/find/basic</A>Instrument Drivers: <A HREF="http://www.agilent.com/find/inst_drivers">http://www.agilent.com/find/inst_drivers</A> <A HREF="http://www.agilent.com/find/inst_drivers_pnp">http://www.agilent.com/find/inst_drivers_pnp</A>> From: chris_gove@Agilent.com> Sent: Friday, April 20, 2001 12:49 PM> To: vrf@lvld.agilent.com> Subject: vrf VEE parallel port control.> I would like an example of a program (VEE or C)to control a> standard parallel(LPT1) port on a pc, to control individual> control or data lines.</pre></blockquote></html>
IOM GmbH
(i.e. Line Feed, Carriage Returns)
I'm trying to display instructions to a user. (i.e. a Calibration sequence)
Right now I'm using a label to display the instructions depending on which
step the user is about to execute.
Thanks in advance for your suggetions
Kevyn R. Pair
Channel Master, LLC.
919-989-1645
