In VEE 6.2,
File -> Default Preferences
and checking "Disable Debug Features" box will
do it.
FUKUI Yutaka
----- Original Message -----
>Subject: [vrf] Master Breakpoint disable setting in Vee 6.1
>Date: Wed, 26 Jul 2006 14:50:09 -0700
>From: "Estrin, Stephen" <ESTRINS@tycoelectronics.com>
>To: VRF <vrf@agilent.com>
>This may sound like a real newbie question, but In Vee 6.1 is there a
>master breakpoint enable/disable setting (like in the preferences) that
>will prevent any set breakpoint from working? I am trying to debug code
>written by someone else, and using the object properties I will set a
>breakpoint and the program will not stop at the breakpoint or any other
>for that matter. I can go to the DEBUG pull down menu and verify that
>activate breakpoints is set but it doesn't make any difference, the
>program just keeps cranking along.
>You are currently subscribed to vrf as: fukui.yutaka@jp.fujitsu.com To
>subscribe please send an email to: "vrf-request@lists.it.agilent.com"
>with
the word subscribe in the message body.
>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".
>To send messages to this mailing list, email "vrf@agilent.com".
>If you need help with the mailing list send a message to
>"owner-vrf@it.lists.it.agilent.com".
>Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".
In VEE 6.2,
do it.
FUKUI Yutaka
>with
