No. When functions are called from a formula input pin they execute atomically, as well as any functions they call (and so on). It works the same way for event handlers. You can't but a breakpoint in atomically executed entities. -SHAWN-
--- You are currently subscribed to vrf as: rsb@soco.agilent.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".
I should also mention that has some fairly heavy duty consequences for so-called "multithreaded" execution. VEE doesn't time slice any atomically executed entity (that's why the breakpoint doesn't work), effectively stopping any other thread. IE, an infinite loop called from a formula input pin stops everything except that one thread. That appears to be quite a common "problem". -SHAWN-
Hi, Has anyone worked with the HP4156 panel driver. It reports errors if I try to change the mode of SMU4 to COMMON in the Sampling mode and reports instrument driver error 1062: No CASE was matched in a select statement in device HP4156A, component SMU4_MODE line 8432. Is this a bug in the panel driver code? Are the panel driver codes reliable or can we expect them to have bugs. If this is a bug, can I get a correct version of the panel driver for HP4156?
Thanks Arunanshu
--- To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".
<html xmlns:v="urn:schemas-microsoft-com:vml" xmlns:o="urn:schemas-microsoft-com:office:office" xmlns:w="urn:schemas-microsoft-com:office:word" xmlns:st1="urn:schemas-microsoft-com:office:smarttags" xmlns="http://www.w3.org/TR/REC-html40"><head><META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=us-ascii"><meta name=Generator content="Microsoft Word 11 (filtered medium)"><!--[if !mso]><style>v:* {behavior:url(#default#VML);}o:* {behavior:url(#default#VML);}w:* {behavior:url(#default#VML);}.shape {behavior:url(#default#VML);}</style><![endif]--><o:SmartTagType namespaceuri="urn:schemas-microsoft-com:office:smarttags" name="PersonName"/><!--[if !mso]><style>st1:*{behavior:url(#default#ieooui) }</style><![endif]--><style><!-- /* Font Definitions */ @font-face {font-family:Tahoma; panose-1:2 11 6 4 3 5 4 4 2 4;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-margin-top-alt:auto; margin-right:0in; mso-margin-bottom-alt:auto; margin-left:0in; font-size:12.0pt; font-family:"Times New Roman"; mso-believe-normal-left:yes;}a:link, span.MsoHyperlink {color:blue; text-decoration:underline;}a:visited, span.MsoHyperlinkFollowed {color:purple; text-decoration:underline;}span.EmailStyle17 {mso-style-type:personal-reply; font-family:Arial; color:navy;}@page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in;}div.Section1 {page:Section1;}--></style><![if mso 9]><style>p.MsoNormal {margin-left:3.0pt;}</style><![endif]></head><body lang=EN-US link=blue vlink=purple style='margin-left:3.0pt;margin-top:3.0pt;margin-right:3.0pt;margin-bottom:.75pt'><div class=Section1><p class=MsoNormal><font size=2 color=navy face=Arial><span style='font-size:10.0pt;font-family:Arial;color:navy'>Sadiya,<o:p></o:p></span></font></p><p class=MsoNormal><font size=2 color=navy face=Arial><span style='font-size:10.0pt;font-family:Arial;color:navy'>Leave the timing data in the G format…subtractit, and then convert to date/time by using to string function.<o:p></o:p></span></font></p><p class=MsoNormal><font size=2 color=navy face=Arial><span style='font-size:10.0pt;font-family:Arial;color:navy'>Han<o:p></o:p></span></font></p><p class=MsoNormal><font size=2 color=navy face=Arial><span style='font-size:10.0pt;font-family:Arial;color:navy'><o:p> </o:p></span></font></p><div><div class=MsoNormal align=center style='margin:0in;margin-bottom:.0001pt;text-align:center'><font size=3 face="Times New Roman"><span style='font-size:12.0pt'><hr size=2 width="100%" align=center tabindex=-1></span></font></div><p class=MsoNormal style='margin:0in;margin-bottom:.0001pt'><b><font size=2face=Tahoma><span style='font-size:10.0pt;font-family:Tahoma;font-weight:bold'>From:</span></font></b><fontsize=2 face=Tahoma><span style='font-size:10.0pt;font-family:Tahoma'> SadiyaFatima [mailto:sfatima@comtechefdata.com] <b><span style='font-weight:bold'>Sent:</span></b> Wednesday, May 24, 2006 8:12AM <b><span style='font-weight:bold'>To:</span></b> VRF <b><span style='font-weight:bold'>Subject:</span></b> [vrf] timing conversions</span></font><o:p></o:p></p></div><p class=MsoNormal><font size=3 face="Times New Roman"><span style='font-size:12.0pt'><o:p> </o:p></span></font></p><p class=MsoNormal style='margin:0in;margin-bottom:.0001pt'><font size=2face=Tahoma><span style='font-size:10.0pt;font-family:Tahoma'>Thank you all forgreat feedback. My next question is if I wanted to find elapsed time between two different times, is there a function in Vee that computes that automatically?
thanks.
--- You are currently subscribed to vrf as: Han.Tran@wdc.com To subscribe please send an email to: "<st1:PersonName w:st="on">vrf-request@lists.it.agilent.com</st1:PersonName>"with the word subscribe in the message body. To unsubscribe send a blank email to"leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "<st1:PersonName w:st="on">owner-vrf@it.lists.it.agilent.com</st1:PersonName>". Search the "unofficial vrf archive" at"www.oswegosw.com/vrf_archive/". <o:p></o:p></span></font></p></div><BR>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body.<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to<BR>"owner-vrf@it.lists.it.agilent.com".<BR>Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".</BODY></html>
executed entities.
-SHAWN-
