>> How many points are you getting?
I am getting 2000 points which is the limit if you decide to choose the
number of points.
>> How many are you expecting?
I would like to get more than that. Until now I am not to sure about how
many, but I am sure that I need more than 2000. Following the scope manual,
it is posible to get around 4 million points. This maximum number is
determined by the equipment.
>> What are your mode/acquisition settings?
I am using SINGLE mode acquisition. I need to get a snap-shot of the
signal. My signal is chaotic, so, if I use NORMAL I got a superposition of
various states of the signal and I am unable to analise it.
I am only setting-up the time and voltage range.
Camps
At 03:52 PM 12/5/2003, Les Hammer wrote:
> > I am trying to get the maximum number of points from an Agilent 54624A
> > Oscilloscope. I put every command that apear in the Programers User
>Guide,
> > unsuccessfully. I am using VEE 5.1 and Windows 95
>Les Hammer
>Partner
>Complete Test
>720 SW 14th St.
>Loveland, CO. 80537
>Les.Hammer@CompleteTest.com
>You are currently subscribed to vrf as: icamps@df.ufscar.br
>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".
>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".
>To send messages to this mailing list, email "vrf@agilent.com".
>If you need help with the mailing list send a message to
>"owner-vrf@it.lists.it.agilent.com".
number of points.
Camps
>Guide,
>Les Hammer
>Partner
>Complete Test
>720 SW 14th St.
>Loveland, CO. 80537
Guide,
Les Hammer
Partner
Complete Test
720 SW 14th St.
Loveland, CO. 80537
