Thanks Sebastian.
> http://www.my-vee.de/download.shtml
I found some good examples there :o)
There are also good information about ID3 tags at this web page: www.id3.org
Alex
From: Donner, Sebastian [mailto:sebastian.donner@kriwan-testzentrum.de]
Sent: den 6 juni 2006 13:42
To: VRF
Subject: AW: [vrf] ID3 TAG's from mp3 file ???
Hi Alex,
Bratbeacker from german VEE board made a program which change de ID3 Tags of mp3 files!
You find the program under http://www.my-vee.de/download.shtml
It use ActiveX.
Sebastian
Von: Alexander Poulikakos (KI/EAB) [mailto:alexander.poulikakos@ericsson.com]
Gesendet: Dienstag, 6. Juni 2006 13:30
An: VRF
Betreff: [vrf] ID3 TAG's from mp3 file ???
Hi VRF
I'm trying to read/edit ID3 TAG information from an mp3 file. I figured there must be a way to do this via .NET, but I can not find it anywhere. Has anyone else done this with VEE/.NET? Does anyone knows how to do this?
I have also looked in the WindowsMediaPlayer ActiveX control but could not figure out what to do.
Any help is appreciated.
/Alex
You are currently subscribed to vrf as: sebastian.donner@kriwan-testzentrum.de
Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte Informationen. Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den Absender und loeschen Sie diese Mail. Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser Mail ist nicht gestattet.
Eingehende E-Mails mit folgenden Anhangs-Endungen werden aus sicherheitsgrnden automatisch abgewiesen:
PIF, SCR, BAT, URL, EXE, COM, DLL, HTA, VBS
This e-mail may contain confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and delete this e-mail. Any unauthorized copying, disclosure or distribution of the contents in this e-mail is strictly forbidden.
Incoming E-Mails with the following attachement-extensions are automatically rejected for security reasons:
You are currently subscribed to vrf as: alexander.poulikakos@ericsson.com
Alex
To: VRF
Hi Alex,
It use ActiveX.
Sebastian
An: VRF
Hi VRF
/Alex
