Isnt it becoming a lit bit easier with .net now to do these windows apis,
and shouldnt you do a "VEE7 beginners guide with .net programming ? "
Thanks so much for your support in the past- and in the future, too.
Best regards,
detlef
I recently cataloged all the functions in all the ActiveX objects on my
system (which is a subset of all the Windows functions available) and the
count was over 175,000!...
...All this is much, much more than any one individual can get through in a
lifetime that includes things other than reading & programming...
This message and any attachments are confidential, for the exclusive use of
the addressee and may be legally privileged. Any other distribution, use or
reproduction is unauthorised and prohibited. If you have received this
message in error, please notify the sender immediately and delete the
message from your system.
Visit our internet site at http://www.pilkington.com
Best regards,
detlef
what can be also a key to your solution:
Use a batch-file for starting VEE. In this batch file you can check for a
dummy file, which is renamed just before launching VEE and which is renamed
back after closing VEE. If the file is present, there is no copy of VEE
running, if you can`t find the file VEE is running actually and you should
not be able to launch it again.
Best regards,
Martin
> -----Ursprngliche Nachricht-----
> Von: Schlieker, Reiner [SMTP:reiner.schlieker@siemens.com]
> Gesendet am: Donnerstag, 20. November 2003 21:54
> An: VRF
> Betreff: [vrf] RE: VEE execution question
> Stan: I reread my message and I guess I should have been more clear. The
> users still need to be able to run other apps, just not while VEE is
> running. While VEE is running, it should be the only app able to run.
> Otherwise, other apps should run as normal.
> William: you have some good suggestions, and I do something similar in my
> normal testers, but this fixture is a simple power up fixture that only
> connects to a PC with RS232. It's used to configure a product before it
> goes out the door. To add an active interlock would add expense and
> complexity, tho I may have to bite the bullet and put it in in the end (I
> was never comfortable with this fixture - I didn't design it)
> Thanks,
> Reiner
> Personally,
> I would prefer not to rely on software at all. I'd change the fixture to
> stay powered down after opening till repowered from the program. I'd
> think
> long and hard about having an open(ed) flag available to the controlling
> program and have it check it on a very regular basis, particularly if it
> is
> about to energize. Another alternative is to put a watchdog timer on
> power
> - The program must continually resend the power up signal, or it powers
> down, but again the interlock flag is needed.
> Depending on the program being up is always risky. A glitch can down the
> code and then power is left on and the operator error is again possible.
> Just a couple thoughts,
> lBill
> "Schlieker, Reiner"
> <reiner.schlieker@s To: VRF
> <vrf@agilent.com>
> iemens.com> cc:
> Subject: [vrf] VEE
> execution question
> 11/20/2003 03:04 PM
> Please respond to
> "Schlieker, Reiner"
> I suspect that to answer this question will require someone with Shawn
> F.-like windows programming experience - here goes...
> Is there any way to exclude any other app except VEE from running in
> Windoze? My problem is that the end users left a test program running,
> minimized it while the UUT was still powered @110VAC (and waiting for user
> input), then started another app. Hours later they removed the UUT from
> the
> fixture (which does have a safety interlock to prevent electrocution)
> without maximizing the VEE program again. Then they put a DC unit in, and
> closed the fixture...BOOM! The program is supposed to be re-executed and
> the unit type barcoded in, so that the program can apply the appropriate
> power, but the program didn't have the chance to do this.
> Not allowing a minimize, and always on top would also work, but I have no
> idea how to do any of this.
> I'm exploring other alternatives, such as a maximum timeout for idle time.
> Thanks in advance.
> _____________________________________
> Reiner Schlieker
> Test Equipment Designer
> Siemens Milltronics Process Instruments Inc.
> Phone: (705) 740-7553
> Fax: (705) 740-7692
> Email: reiner.schlieker@siemens.com
> Web: www.siemens-milltronics.com
> You are currently subscribed to vrf as: lbill@us.ibm.com
> You are currently subscribed to vrf as: Martin.Alles@hno.atmel.com
