> Wonderful Walpurgis
Hey - that's on the other side of the Zodiac. Have another cocktail.
failing with Access Denied. That can only mean that the thread that's
calling it does not belong to the VEE process, but I thought that I was
making an in-process server. Rather than fight VB, I'm going to change tack
here a little.
It was a good thought, but this method will obviously not work. I need *two*
dlls: one regular compiled dll that contains the subclassing WindowProc and
two functions: one returns the address of said WindowProc and one sets the
value of a global that's a reference to the Automation object that fires the
event. The other dll is the Automation library containing a single event
that is used to relay notification to VEE. I hope the whole thing can be
installed on the fly, but the event plumbing may prevent that - I don't know
yet.
It's getting spooky kids! Now I have to try to remember how to use
_com_ptr_t and I dunno if I can do that before tomorrow morning, though it
will be worth having a generalized callback method for VEE 5 & above.
-SHAWN-
