vrf How do I use a collector inside a user object?
Question asked by scubaman on Nov 13, 2003
WIBNI there were non-required input pins for user objects or functions,
like control inputs?  Maybe in Vee 7.01?
Rich
Richard Kleinhenz
Wafer Engineering
845-892-2617
scubaman@us.ibm.com
                      "Hartley, LL
                      Larry (6245) @           To:       VRF <vrf@agilent.com>
                      IS"                      cc:
                      <Larry.Hartley           Subject:  [vrf] RE: vrf: How do I use a collector inside a user object?
                      11/14/2003 09:05
                      AM
                      Please respond to
                      "Hartley,LL Larry
                      (6245)
If all the data collected is similar, try concatenating the collectors into
a global. This allows access from any user object or function anywhere in
your program.
Sent: Thursday, November 13, 2003 9:30 PM
To: VRF
Subject: [vrf] vrf: How do I use a collector inside a user object?
Hello VEE users,
My VEE program is beginning to look pretty spaghetti-ish. My problem is:
I can't put all those lovely little collectors into user objects (or
functions) and continue to collect data into them........
The XEQ pin won't fire on the collector object when it's not in the same
environment as the For Loop object. Now I know some of you real seasoned
veterans out there are snickering right now but please humor me just one
more time & lead me down the rosy path.
Many thanks.
<<LoopingAndCollectors.vee>>
You are currently subscribed to vrf as: scubaman@us.ibm.com
#### Collector.vee has been removed from this note on November 14, 2003 by
Richard Kleinhenz
