Hello Fernado,
Thanks for the tip. I check my .net and it is only 1.1x. So I uninstalled the 1.1 and installed 2.0 (from MS site). Now nothing works
Vee refuses to open claiming that net 1.1x must be installed.
Darn. If I have net 1.1 the Vee works but mail not. If I have net 2.0 the mail (probably) works but vee not.
I suppose I need to reinstall Vee & automation suite next...
Br, Tapio
>-----Original Message-----
>From: ext Nuñez Correa, Fernando [mailto:fnunez@indra.es]
>Sent: 06 June, 2006 09:29
>To: VRF
>Subject: RE: [vrf] Strange error on SmtpMail.Send function (build in)
>Hi. I use SmtpClient to send mails... Look the file... I use .NET
>Framework 2.0 ...
>Regards.
>Fernando Núñez Correa
>C/ Mar Egeo 4, Pol. Industrial nº1
>San Fernando de Henares
>28830 - Madrid (ESPAÑA-SPAIN)
>Tel: +34 91 626 89 52
>Fax: +34 91 626 88 90
>fnunez@indra.es
>www.indra.es/space
>www.indra.es/espacio
>-----Mensaje original-----
>De: tapio.ronkainen@nokia.com [mailto:tapio.ronkainen@nokia.com]
>Enviado el: lunes, 05 de junio de 2006 13:15
>Para: VRF
>Asunto: [vrf] Strange error on SmtpMail.Send function (build in)
>Has anyone seen this happening before?
>I have "standard" Vee 7.52 installed to XP machine and up to now the
>SmtpMail.send has worked as it should but today I started receiving the
>(attached pic) error. I wrote a short test program by just using a
>bunch of text contants as input and one SmtpMail.send object. Still the
>same error.
>Rebooted... Still the same...
>Where should I look to get this one solved? As far as I know there
>should be no OS related updates lately (well, You never know this in
>big company in this PC.
>All help is welcome,
>BR, Tapio
>You are currently subscribed to vrf as: fnunez@indra.es To subscribe
>please send an email to:
>"vrf-request@lists.it.agilent.com" with the word subscribe in the
>message body.
>To unsubscribe send a blank email to
>"leave-vrf@it.lists.it.agilent.com".
>To send messages to this mailing list, email "vrf@agilent.com".
>If you need help with the mailing list send a message to
>"owner-vrf@it.lists.it.agilent.com".
>Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".
>tapio.ronkainen@nokia.com To subscribe please send an email
>to: "vrf-request@lists.it.agilent.com" with the word subscribe in the
>message body.
Br, Tapio
>To: VRF
>Framework 2.0 ...
>Regards.
>fnunez@indra.es
>www.indra.es/space
>Para: VRF
>same error.
>BR, Tapio
>message body.
>message body.
reflector yet?" (we're colleages, if you haven't figured that out!) Wow,
great responses. Thanks to everybody. Unfortunately, like Shaun said, I
don't have a Thermotron yet in order to test it - I was trying to figure out
whether this was the one to buy...
Reiner
From: Shaun Harwood [mailto:shaun.harwood@sympatico.ca]
Sent: Sunday, June 04, 2006 10:28 PM
To: VRF
Subject: RE: [vrf] VEE and Thermotron
Nice work
Attached has been altered - still unable to try without a unit to play with
but it shouldn't be too far off the mark now.
Best regards
Shaun H
From: Shawn Fessenden [mailto:shawnfess@comcast.net]
Sent: Saturday, June 03, 2006 11:24 PM
To: VRF
Subject: FW: [vrf] VEE and Thermotron
Sure thing Les (the following is brought to you by Les Hammer).
We now know a ViObject is a long and a ViSession is a long. Good call on
ViBoolean aye? And the equivalent is? short! Reiner, this is basically all
the info necessary to get the IVI driver working - without going through the
IVI VEE thing.
-SHAWN-
From: leshammer@frii.com [mailto:leshammer@frii.com]
Sent: Saturday, June 03, 2006 8:11 PM
To: Shawn Fessenden
Hi Shawn,
Could you please forward this on to vrf. I'm on my other computer and vrf
doesn't know the alternate email name.
> There are three unknowns now:
> ViResource, ViSession and ViBoolean.
>From visatype.h:
typedef unsigned long ViUInt32;
typedef unsigned short ViUInt16;
typedef ViUInt32 ViObject;
typedef ViObject ViSession;
typedef ViUInt16 ViBoolean;
I don't see ViResource, but:
#if (defined(WIN32) || defined(_WIN32) || defined(__WIN32__) ||
defined(__NT__)) && !defined(_NI_mswin16_) #define _VI_FAR #elif
defined(_CVI_) && defined(_NI_i386_) #define _VI_FAR ##elif
(defined(_WINDOWS) || defined(_Windows)) && !defined(_NI_mswin16_)
#define _VI_FAR _far
#elif (defined(hpux) || defined(__hpux)) && (defined(__cplusplus) ||
defined(__cplusplus__))
#define _VI_FAR
#else
#define _VI_FAR
#endif
#define _VI_PTR _VI_FAR *
typedef char ViChar;
typedef ViChar _VI_PTR ViPChar;
typedef ViPChar ViString;
typedef ViString ViRsrc;
~~Les Hammer
You are currently subscribed to vrf as: shaun.harwood@sympatico.ca To
You are currently subscribed to vrf as: reiner.schlieker@siemens.com
