I am going to go out on a limb here and make a blanket statement that you
are not going to see the improvements you need simply by moving to a faster
processor.
The problem is not a simple one to answer as the exact numbers are tied up
in things like windows non-real time behaviour. This means that you cannot
guarantee when you will get access to your card, nor how long you will have
access before swapping out.
In order to meet your goals, I believe you need one of two changes. The
first would be to go with a data acq card that had enough reading buffer
that you could fill it at your data rate and then burst it out when you got
windows access. Something like a 10 reading memory should suffice.
The second possibility is to go with a real time operating system. This
would guarantee response in a particular time window. Assuming that the DAQ
card can read at this rate, it would solve the job. However, at this point
we are in the wrong group to be discussing this as VEE is not a real time
app.
Jay Nemeth-Johannes
Complete Test
720 SW 14th Street
Loveland, Colorado 80537
www.completetest.com
> -----Original Message-----
> From: Brutzman, Bill [mailto:BillB@hkMetalCraft.com]
> Sent: Thursday, December 11, 2003 9:14 AM
> To: VRF
> Cc: Gross, Jim; 'Marc@MeadowFace.net'; Osborn, Bob; Hopp, Raymond
> Subject: [vrf] VEE Speed Question
> We would like our test equipment [under development] to be able to take
> measurements every 0.5 msec.
> Right now, our current Win98 PC, Pentium III, 550 MHz, 128 MB ram seems to
> max out at measurements every 3 msec.
> We measure thickness of 1/2" washers using a rotating bowl, shaft encoder,
> laser, and A/D card.
> I am writing to request estimates on speed improvements we can expect to
> see
> by installing a faster PC.
> I am wondering about CPU speed, memory for speed, XP for speed.
> Dell catalog indicates...
> Price CPU [GHz] Up to [GHz] with Front Side Bus
> $599 P4 2.4 2.4 400 MHz
> $999 P4 2.6 3.2 800
> HyperThread
> $1099 P4 2.8 3.2 800
> HyperThread
> $1249 Xeon 2.4 3.2 - Dual
> Processor Capable
> $1399 Xeon 2.66 3.2 -
Dual
> Processor Capable
> Suggestions would be appreciated. Of course, we would like to get it
> right
> the first time.
> Regards,
> Bill Brutzman, Manager IT
> HK MetalCraft Mfg Corp
> PO Box 775
> 35 Industrial Road
> Lodi NJ 07644-0775
> 973.471.7770 x145 .voice
> 973.471.9666 .fax
> www.hkMetalCraft.com
> You are currently subscribed to vrf as: jay.johannes@completetest.com
> If you need help with the mailing list send a message to "owner-
processor.
app.
Jay Nemeth-Johannes
Complete Test
720 SW 14th Street
> To: VRF
> see
> $999 P4 2.6 3.2 800
> HyperThread
> HyperThread
> Processor Capable
Dual
> Processor Capable
> right
> the first time.
> Regards,
> PO Box 775
> 35 Industrial Road
> Lodi NJ 07644-0775
> 973.471.9666 .fax
up
> with my own wacky way of doing it, but I'd like something mathematically
> cleaner. Ideally, I'd like a user function that returns the relative
radius
> of every point on my curve.
Personally I'd use numerical analysis routines to calculate the first
(and maybe second) derivative at each point. VEE has deriv(x,order)
for this.
Les Hammer
Partner
Complete Test
720 SW 14th St.
Loveland, CO. 80537
Les.Hammer@CompleteTest.com
