To add further information to my mail 31.8.06 12:06 (MEZ=GMT+1h) I have attached the GPIBREP.TXT, which was established today.
You can find, that *IDN?, *STB? and *OPC? worked properly. As well as the simple command: MEAS:VOLT:DC? which delivered an answer (nothing on the input!).
Â
I cannot understand why VEE does not do the same.
Strange: When I'm using the instrument manager of VEE (IO-Setup is included in the program), and ask for [Find Instruments] it offers me beside the serial ports and the GPIB32 with all connected instruments a GPIB14 -this was the old one!- having a new instrument of no response at 1422=> timeout.Â
Very strange.
Â
Peter Weber
HYPERLINK "http://www.pcmess.com"www.pcmess.com
Birkenweg 8, D-87677 Stoettwang
Tel: +49(0)8345-482
Wir halten unseren Internetzugang sauber mit Symantec-Produkten in der jeweils neuesten Version. Dies auch bei allen E-Mails.
We keep our internet connection clean using Symantec products of the latest version. This applies also to all e-mailing.
Â
Very strange.
Â
Peter Weber
Tel: +49(0)8345-482
I dont want the vee generated headline with date and time on the top.
Is it possible to switch this off ?
regards
Siegfried Lauble
Junghans Feinwerktechnik
Unterbergenweg 10
78655 Dunningen
Tel.: 07402/181-96
Fax: 07402/181-32
mailto:siegfried.lauble@junghans-fwt.de
English : autocreated E-Mail Appendix: The content of this E-Mail is not legally binding upon Junghans, even though the certified electronic signature technique may point to the writer of the E-Mail. If this E-Mail was transmitted to you by error, then please inform us accordingly (+49
7402 181-181). In such case you are requested to erase the message. Any unauthorized reproduction, disclosure, modification, distribution and/or publication of such E-Mail message is strictly prohibited.
Deutsch : automatisch erzeugter E-Mail Anhang: In Verbindung mit Kostenuebernahmen, Lieferungen, Angeboten und Vertraegen ist der Inhalt dieses E-Mails fuer Junghans rechtlich nicht verbindlich, auch wenn die Anwendung des elektronischen, zertifizierten Signaturverfahrens den Ersteller des E-Mails nachweist. Informieren Sie uns bitte, wenn Sie dieses E-Mail faelschlicherweise erhalten haben (+49 7402 181-181). Bitte löschen Sie in diesem Fall die Nachricht. Jede unerlaubte Form der Reproduktion, Bekanntgabe, Aenderung, Verteilung und/oder Publikation dieser E-Mail ist strengstens verboten.
>>>>>>>>>> This mail and its attachments are virus-checked! <<<<<<<<<<
Agilent's Connection Expert Version 14.2 (thank you Stan) finds the instrument correctly at GPIB0, address 22 as it is. *IDN? is performed correctly.
Manual check by means of SCPI: MEAS:VOLT:DC? works perfectly. The answer is coming back to the PC.
Strange: my VEE-Program (VEE 6.2) works fine until it comes to read the results of the calculation of 15 values=> it times out. (IO-monitor stops after TALK 22!)Â Note: all commands are transferred, a serial poll had been successfully done before the measurement started. There's no command error as the program ran perfectly alright.
*I'm a bit lost* and would like to have a good idea!
Â
Â
Peter Weber
Tel: +49(0)8345-482
