Martin has a great idea here --
My solution is to build well thought out, robust programs that have their
own debug hooks in them. Log files, etc..
Of course, I don't follow my own advice
From: "MartÃn Castillejos, Juan Carlos" [mailto:jcmartin@indra.es]
Sent: Tue 11/4/2003 1:54 AM
To: VEE vrf
Cc:
Subject: [vrf] RE: vrf: VEE Licensing - P.S.
Maybe a silly suggestion but...
Imagine that VEE-RUN has two different modes:
a) By default up to now: only runtime.
b) A new mode that could be called by using a qualifier like debugging for
that purpose that could be executed like the maximize qualifier, for
example: veerun -debug.
In this new mode you could use all the debugging features of VEE Test (see
code, show execution flow, show execution data flow, check global variable
values, etc). But you cannot replace, create or delete any object. In fact
you cannot modify anything and of course you cannot write a new file.
I can see that this new mode (runtime debugging) could need a heavy
installation of veerun. Maybe it would need to decide if installing vee
runtime alone or with debugging tools.
Could this approach help to solve the license item?
On the other hand and in any case I think that VEERUN needs to provide more
information about which is the specific object that has provoked an error,
and VEE test need a better error trap.
regards,
-----Mensaje original-----
De: scott_bayes@agilent.com [mailto:scott_bayes@agilent.com]
Enviado el: martes, 04 de noviembre de 2003 0:11
Para: VEE vrf
CC: vrf@it.lists.it.agilent.com
Asunto: [vrf] RE: vrf: VEE Licensing - P.S.
Hi Rob and the vrf,
I think I know what you're requesting, and I agree, 6.2 licensing does not
provide it.
6.2 allows you to use one license wherever you happen to need to, but you
should only execute Pro on one computer at a time for one license. It does
not allow you to use multiple copies of Pro on one license, where all or a
subset of the copies may be in use at the same time. For that, you currently
need to buy N licenses at full price, where N is the number of simultaneous
uses of Pro. For you, N is fairly large, creating a cost problem.
I think you're after a "site license" or maybe a volume license that brings
down the cost when you need to populate many computers legally with VEE Pro,
not VEE RUN. You need VEE Pro rather than RUN because of the better
application management (debug, deploy, troubleshoot, etc) supported by Pro.
Hope I've described your situation correctly.
I am not a decision-maker on that kind of product issue, but I have
forwarded your requirement to our Product Management and R&D folks, and I
believe I can represent your needs to them pretty well. Whether and what
might happen I can't say, but your request has definitely been heard here at
high levels and low, by the right people.
There may be alternatives to the above site or volume license possibility,
but they require some more thought. Maybe some way to "beef up" VEE RUN so
that it's a more practical deployment/troubleshoot-and-fix tool...
Or maybe a passworded switch by which you can leave Pro installed but have
it run "dumb" as VEE RUN, unless you need to work on the code, in which case
you could throw the switch to smarten it up again. This would relieve the
install/uninstall pushups.
Anyway, I hope this response helps.
(BTW, for me, the difficulty is differentiating between the OS and a virus.
They can both be so perverse
Best Regards,
Scott Bayes
Software Technical Support
Agilent Technologies, Inc.
815 14th Street S.W.
Loveland, CO, U.S.A. 80537
970 679 3799 Tel
970 635 6867 Fax
From: ramarquardt@ra.rockwell.com [mailto:ramarquardt@ra.rockwell.com]
Sent: Monday, November 03, 2003 2:50 PM
To: VEE vrf
Subject: [vrf] vrf: VEE Licensing - P.S.
P.S.
The fact that we have proliferated full development licenses on many testers
over the
last 9 years is creating a large problem for us.
We have many testers running VEE 4.01. Many have VEE 5 and a few have VEE 6
licenses
but we are running VEE 4.01 to keep version management manageable. We want
to
upgrade to VEE 7 but it has become cost prohibitive because we cannot
justify
buying licenses for all the production testers. It is more important to have
the ability
to quickly troubleshoot production equipment than it is to have the latest
software.
Please come up with a solution soon, so we can upgrade and migrate to
VEE 7 and Windows XP - Virus Edition [Pun intended, I think Windows is, per
se, a virus].
Thanks for listening
....Rob
--- You are currently subscribed to vrf as: scott_bayes@agilent.com To
subscribe send a blank email to "join-vrf@it.lists.it.agilent.com". To
unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To
send messages to this mailing list, email "vrf@agilent.com". If you need
help with the mailing list send a message to
You are currently subscribed to vrf as: jcmartin@indra.es
Este correo electrónico y, en su caso, cualquier fichero anexo al mismo,
contiene información de carácter confidencial exclusivamente dirigida a su
destinatario o destinatarios. Queda prohibida su divulgación, copia o
distribución a terceros sin la previa autorización escrita de Indra. En el
caso de haber recibido este correo electrónico por error, se ruega notificar
inmediatamente esta circunstancia mediante reenvÃo a la dirección
electrónica del remitente.
The information in this e-mail and in any attachments is confidential and
solely for the attention and use of the named addressee(s). You are hereby
notified that any dissemination, distribution or copy of this communication
is prohibited without the prior written consent of Indra. If you have
received this communication in error, please, notify the sender by reply
e-mail ---
You are currently subscribed to vrf as: jeff.davis@cdi-es.com
________________________________________________________________________
This email has been scanned for all viruses by the MessageLabs Email
Security System. For more information on a proactive email security
service working around the clock, around the globe, visit
http://www.messagelabs.com <http://www.messagelabs.com>
To: VEE vrf
Cc:
regards,
Para: VEE vrf
Hi Rob and the vrf,
provide it.
Best Regards,
Scott Bayes
970 679 3799 Tel
970 635 6867 Fax
To: VEE vrf
P.S.
over the
licenses
to
justify
the ability
software.
se, a virus].
....Rob
e-mail ---
<font size=2 face="sans-serif">P.S.</font>
<font size=2 face="sans-serif">The fact that we have proliferated full development licenses on many testers over the</font>
<font size=2 face="sans-serif">last 9 years is creating a large problem for us.</font>
<font size=2 face="sans-serif">We have many testers running VEE 4.01. Many have VEE 5 and a few have VEE 6 licenses</font>
<font size=2 face="sans-serif">but we are running VEE 4.01 to keep version management manageable. We want to</font>
<font size=2 face="sans-serif">upgrade to VEE 7 but it has become cost prohibitive because we cannot justify</font>
<font size=2 face="sans-serif">buying licenses for all the production testers. It is more important to have the ability</font>
<font size=2 face="sans-serif">to quickly troubleshoot production equipment than it is to have the latest software.</font>
<font size=2 face="sans-serif">Please come up with a solution soon, so we can upgrade and migrate to </font>
<font size=2 face="sans-serif">VEE 7 and Windows XP - Virus Edition [Pun intended, I think Windows is, per se, a virus].</font>
<font size=2 face="sans-serif">Thanks for listening</font>
<font size=2 face="sans-serif">....Rob</font>
---You are currently subscribed to vrf as: rsb@soco.agilent.comTo subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".
