I checked the entry on my computer and found
"C:ProgrammeAgilentVEE Pro RunTime 6.2\veerun.exe" "%1",
the same as in [HKEY_CLASSES_ROOTVEE.RunTimeProgramshellOpencommand].
I changed the entry to "C:ProgrammeAgilentVEE Pro 6.2\vee.exe" "%1",
but it did not solve the problem.
Re-booting the computer did not help either.
By the way this reminds me, that there is a bug in the installation software
of VEE6.2. I first installed VEE6.2 development version and this seemed to
work fine. Then I installed VEE6.2 runtime version. Double clicking on *.vee
files then started the runtime version instead of the development version.
This mistake is new in VEE6.2.
Hans-Joachim Fischer
Von: g.nied@gn-software.de [mailto:g.nied@gn-software.de]
Gesendet: Dienstag, 25. November 2003 10:13
An: VRF
Betreff: [vrf] Re: Windows 16 bit functions in VEE 6.2
As far as I can remember this was due to a wrong entry in the registry.
Check your entry under
[HKEY_CLASSES_ROOTVEE.ProgramshellOpencommand]
mine is:
"C:ProgrammeHewlett-PackardVEE 5.0vee.exe" "%1"
including all the quotation marks. Especially around %1
Hope it helps,
G. Nied
Georg Nied - Software-Development - Hansestr.7 - 51149 Cologne - Germany
Tel: +49 2203 9770915 - Fax: +49 2203 9770924 - eMail:info@gn-software.de
-------- Original Message --------
Subject: [vrf] Windows 16 bit functions in VEE 6.2 (25-Nov-2003 9:05)
To: vrf@agilent.com
> Dear all,
> I graded up from VEE 6.01 to VEE 6.2 and found the following new effect.
> Assume a folder with a file "testfile1.vee".
> Double clicking on "testfile1.vee" starts VEE and loads this file, however
> in the blue bar on top of the window, you can read the file name
> "testfi~1.vee". This well-known 16-bit feature is not very nice, as
> subsequent saving of the program will actually generate a file with name
> "testfi~1.vee".
> Starting VEE and then opening a file from the file menu does not show this
> mistake.
You are currently subscribed to vrf as: vee@esf-gmbh.de
An: VRF
mine is:
Hope it helps,
G. Nied
To: vrf@agilent.com
> Dear all,
> "testfi~1.vee".
> mistake.
