Thomas.Mitchell@Autoliv.com wrote:
> I have a question for all of the experts on using Matlab in VEE. I'm
> trying to import some Matlab code into my VEE program. We're decoding an
> Manchester encoded digital signal and one of our engineers wrote a Matlab
> script to do this. As part of his script, he reads and writes to excel
> from Matlab. I'm assuming with some ActiveX control.
from your code snippet below it appears to use the Excell Link Toolbox.
Not at all sure that Matlab can do ActiveX.
> When I copy and paste his script in my program, it runs fine until it gets
> to the point where it tried to read the data from excel. I haven't tried
> the write section yet, but I'm sure it will not work in its present form.
> %Import Excel lookup table to convert digital messages from hex to decimal
> format
> [xlsdata xlshex] = xlsread(' Output_02.xls');
> for j = 1:length(hex_data_message),
> accel_dig(j) = xlsdata(strmatch(hex_data_message(j), xlshex));
> end
Are you using the Matlab Script that comes with VEE or have you linked
to a full install of Matlab? If the former you will have problem
since script doesn't include Excel Link.
If the latter- do you have Excel Link toolbox available?
Stan
> format
> end
Stan
This is the code in question is::::::
format
end
accel_dig = accel_dig';
%Write decimal accel digits to file
writename = [filename(1:findstr(filename,'.')-1) '_dig_out.xls'];
xlswrite(accel_dig,'','',writename);
winopen('Creg_data.xls');
VEE has a problem with xlsread. Any ideas?
Thanks
Tom Mitchell
Autoliv
