vrf HP VNA
Question asked by mwills on Nov 5, 2003
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"><HTML xmlns="http://www.w3.org/TR/REC-html40" xmlns:o = "urn:schemas-microsoft-com:office:office" xmlns:w = "urn:schemas-microsoft-com:office:word"><HEAD><META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=US-ASCII"><META content=Word.Document name=ProgId><META content="MSHTML 6.00.2800.1226" name=GENERATOR><META content="Microsoft Word 10" name=Originator><LINK href="cid:filelist.xml@01C2E55A.A1D98640" rel=File-List><!--[if gte mso 9]><xml> <o:OfficeDocumentSettings>  <o:DoNotRelyOnCSS/> </o:OfficeDocumentSettings></xml><![endif]--><!--[if gte mso 9]><xml> <w:WordDocument>  <w:SpellingState>Clean</w:SpellingState>  <w:GrammarState>Clean</w:GrammarState>  <w:DocumentKind>DocumentEmail</w:DocumentKind>  <w:EnvelopeVis/>  <w:Compatibility>   <w:BreakWrappedTables/>   <w:SnapToGridInCell/>   <w:WrapTextWithPunct/>   <w:UseAsianBreakRules/>  </w:Compatibility>  <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument></xml><![endif]--><STYLE>@page Section1 {size: 612.0pt 792.0pt; margin: 72.0pt 90.0pt 72.0pt 90.0pt; mso-header-margin: 35.4pt; mso-footer-margin: 35.4pt; mso-paper-source: 0; }P.MsoNormal {     FONT-SIZE: 12pt; MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman"; mso-style-parent: ""; mso-pagination: widow-orphan; mso-fareast-font-family: "Times New Roman"}LI.MsoNormal {     FONT-SIZE: 12pt; MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman"; mso-style-parent: ""; mso-pagination: widow-orphan; mso-fareast-font-family: "Times New Roman"}DIV.MsoNormal {     FONT-SIZE: 12pt; MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman"; mso-style-parent: ""; mso-pagination: widow-orphan; mso-fareast-font-family: "Times New Roman"}A:link {     COLOR: blue; TEXT-DECORATION: underline; text-underline: single}SPAN.MsoHyperlink {     COLOR: blue; TEXT-DECORATION: underline; text-underline: single}A:visited {     COLOR: purple; TEXT-DECORATION: underline; text-underline: single}SPAN.MsoHyperlinkFollowed {     COLOR: purple; TEXT-DECORATION: underline; text-underline: single}SPAN.EmailStyle17 {     COLOR: windowtext; FONT-FAMILY: Arial; mso-style-type: personal-compose; mso-style-noshow: yes; mso-ansi-font-size: 10.0pt; mso-bidi-font-size: 10.0pt; mso-ascii-font-family: Arial; mso-hansi-font-family: Arial; mso-bidi-font-family: Arial}DIV.Section1 {     page: Section1}</STYLE><!--[if gte mso 10]><style> /* Style Definitions */  table.MsoNormalTable     {mso-style-name:"Table Normal";     mso-tstyle-rowband-size:0;     mso-tstyle-colband-size:0;     mso-style-noshow:yes;     mso-style-parent:"";     mso-padding-alt:0cm 5.4pt 0cm 5.4pt;     mso-para-margin:0cm;     mso-para-margin-bottom:.0001pt;     mso-pagination:widow-orphan;     font-size:10.0pt;     font-family:"Times New Roman";}</style><![endif]--></HEAD><BODY lang=EN-US style="tab-interval: 36.0pt" vLink=purple link=blue><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=343483314-05112003>Hi Mr Atkinson,</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=343483314-05112003></SPAN></FONT> </DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=343483314-05112003>It was a long time ago that I programmed this instrument and I cannot find the code at the moment. I believe that there was not an explicit command to omit isolation, so the following had to be done using the SOFT key options, assuming a 2-port cal.</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=343483314-05112003></SPAN></FONT> </DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=343483314-05112003>1.setup for the net analyser</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=343483314-05112003>2."CALK35MD;"    // set calkit type</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=343483314-05112003>3."CALIFUL2;"    // set full 2-port cal</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=343483314-05112003>4."ISOL"    // select isolation</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=343483314-05112003>5."SOFTx"    // where x is the corresponding softkey for 'omit isolation' (down the right hand side of the screen)</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=343483314-05112003></SPAN></FONT> </DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=343483314-05112003>I apologise if I have missed any steps but basically once you have sent the command to access the the menu that is required, then execute the appropriate 'soft key' for the task you wish to execute. This principle can be applied to any menu.</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=343483314-05112003></SPAN></FONT> </DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=343483314-05112003>I hope that this helps.</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=343483314-05112003></SPAN></FONT> </DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=343483314-05112003>Regards,</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=343483314-05112003>Mark Wills</SPAN></FONT></DIV><BLOCKQUOTE>  <DIV class=OutlookMessageHeader dir=ltr align=left><FONT face=Tahoma   size=2>-----Original Message-----<BR><B>From:</B> Atkinson Mr M   [mailto:M.Atkinson@rmcs.cranfield.ac.uk]<BR><B>Sent:</B> 05 November 2003   10:08<BR><B>To:</B> VEE vrf<BR><B>Subject:</B> [vrf] HP   VNA<BR><BR></FONT></DIV>  <DIV class=Section1>  <P class=MsoNormal><FONT face=Arial size=2><SPAN lang=EN-GB   style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-ansi-language: EN-GB">Hello,<o:p></o:p></SPAN></FONT></P>  <P class=MsoNormal><FONT face=Arial size=2><SPAN lang=EN-GB   style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-ansi-language: EN-GB">I'm   struggling with the full 2-port calibration of my HP8719c VNA. I would like to   OMIT ISOLATION but I don't how to do it in VEE. Has someone done the same kind   of work already?<o:p></o:p></SPAN></FONT></P>  <P class=MsoNormal><FONT face=Arial size=2><SPAN lang=EN-GB   style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-ansi-language: EN-GB">Thanks   for your help, Matt<o:p></o:p></SPAN></FONT></P></DIV>---<BR>You are currently   subscribed to vrf as: MWills@tycoelectronics.com<BR>To subscribe send a blank   email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank   email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this   mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing   list send a message to "owner-vrf@it.lists.it.agilent.com". <BR>-- <BR>This   message has been scanned for viruses and <BR>dangerous content by the   Cranfield MailScanner, and is <BR>believed to be clean. </BLOCKQUOTE>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list,  email "vrf@agilent.com".  <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</BODY></HTML>
