vrf 16-port serial PCI
Question asked by jcmartin on Nov 11, 2003
Be careful of:
a) Update the SICL with new ports.
b) Check that new ports in the OS (COMx) get the same logial unit in SICL (click into the com port and use edit button). Take into account that there are some addresses that are reserved and they are not allowed to be used (If I rmember good 14, 15). Due to that I use to install COM ports from 21 to 39 for RS422-485 and for 41 to 99 for RS232.
regards,
> -----Mensaje original-----
> De: John Graves [mailto:john.graves@recreation.bombardier.com]
> Enviado el: lunes, 10 de noviembre de 2003 20:14
> Para: VRF
> Asunto: [vrf] 16-port serial PCI
> I am proposing a question for the best way to interface with
> my Rockport PCI 16-port serial card and interface.
> (Comtrol Rocket Port PCI card #95750-8 and interface# 97100-9)
> It has been working just fine with using 10 ports, i have
> added 5 additional items to communicate with and now I have
> it has problems.  Errors out and tells me the port i am
> trying to access has not been set up,
> but it is in the I/O configuration.  And it gives me no errors there.
> Ideas or suggestions
> thanks
> John K. Graves - Test Engineer
> Boats and Outboard Engines Division
> Bombardier Recreational Products
> 329 Hallberg Street
> Delavan, WI  53115
> You are currently subscribed to vrf as: jcmartin@indra.es
> To send messages to this mailing list,  email "vrf@agilent.com".
Este correo electrnico y, en su caso, cualquier fichero anexo al mismo, contiene informacin de carcter confidencial exclusivamente dirigida a su destinatario o destinatarios. Queda prohibida su divulgacin, copia o distribucin a terceros sin la previa autorizacin escrita de Indra. En el caso de haber recibido este correo electrnico por error, se ruega notificar inmediatamente esta circunstancia mediante reenvo a la direccin electrnica del remitente.
The information in this e-mail and in any attachments is confidential and solely for the attention and use of the named addressee(s). You are hereby notified that any dissemination, distribution or copy of this communication is prohibited without the prior written consent of Indra. If you have received this communication in error, please, notify the sender by reply e-mail
