Hi Ram,
the notepad is only to use like a comment in program. It does nothing but showing his note text. If you click the right mouse button for the 'Properties...', there is a checkbox for 'Editing'. If this is 'Enabled', you can change the text.
To bring the notepad to the front, please mark it and then go to the top line. In 'Edit', there is a item 'Add To Panel', which will show the marked things on the top main panel.
When I started with VEE, I got a few hours startup training from the company where I bought VEE. This was a good way for me to see the features and saved me a lot of time. So I can recommend such a starter training by heart.
Good luck to you,
/Stefan
Von: amilineni rammohanchowdary [mailto:rammohanchowdary@yahoo.com]
Gesendet: Mittwoch, 10. Dezember 2003 13:06
An: VRF
Betreff: [vrf] Regarding the basics of vee pro
Hello all,
What is the difference between notepad and the
userobject. BOth look same when u see the examples ,
how can we add another object in the front and change
the back ground in the userobject . and how can we
write some notes in the notepad and edit it.
please help me
ram
__________________________________
Do you Yahoo!?
Protect your identity with Yahoo! Mail AddressGuard http://antispam.yahoo.com/whatsnewfree
You are currently subscribed to vrf as: Stefan.Paulick.extern@brose.net To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".
Good luck to you,
/Stefan
An: VRF
Hello all,
please help me
ram
Do you Yahoo!?
