<DIV><DIV>I have written an application in VEE Pro that uses activex to export data to excel for printing of data sheets. I am having a problem with the excel date time format. I formatted the VEE data into date/time strings that are a valid input in excel if you type them in manually, but when the program inputs the data excel thinks they are text strings and does not recognize them as a date/time. If I open the data sheet in excel and double-click the cell containing the string and then exit the cell without editing, excel then recognizes it as a date/time. I worked around the problem by writing a function to convert the VEE (now) output to an excel time number and writing that to excel but it is always UTC based. Is there a way around this behavior?</DIV><DIV>Thanks,</DIV><DIV>Dave</DIV></DIV><p><hr SIZE=1>Do you Yahoo!?
Yahoo! SiteBuilder - Free web site building tool. <a href="http://us.rd.yahoo.com/evt=21608/*http://webhosting.yahoo.com/ps/sb/"><b>Try it!</b></a>---You are currently subscribed to vrf as: rsb@soco.agilent.comTo subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".Send your favorite VEE example to "VRF-EXAMPLES@agilent.com" for possible inclusion in VEE 7.0!
