<font size=2 face="sans-serif">Hello Hans,</font>
<font size=2 face="sans-serif">Your vee.io file for the runtime does NOPT match your vee.io for the development mode.
</font>
<font size=2 face="sans-serif">Copy the C:Documents and Settings
amarquaLocal SettingsApplication DataAgilentVEE Provee.io file</font>
<font size=2 face="sans-serif">to the C:Documents and Settings
amarquaLocal SettingsApplication DataAgilentVEE Run directory</font>
....Rob</font>
Rob Marquardt
Rockwell Automation / Allen-Bradley
1201 So. 2nd St. / T131
Milwaukee, WI. 53204-2496
USA
ramarquardt@ra.rockwell.com
414-382-3098
414-382-4820 (FAX)
</font>
<table width=100%><tr valign=top><td><td><font size=1 face="sans-serif"><b>"VEE user at ESF GmbH" |vee@esf-gmbh.de></b></font><p><font size=1 face="sans-serif">11/12/2003 01:48 AM</font>
<font size=1 face="sans-serif">Please respond to "VEE user at ESF GmbH"</font>
<td><font size=1 face="Arial"> </font>
<font size=1 face="sans-serif"> To: VRF |vrf@agilent.com></font>
<font size=1 face="sans-serif"> cc: </font>
<font size=1 face="sans-serif"> Subject: [vrf] VEE Error 801</font></table>
<font size=2><tt>Dear VEE experts,
</tt></font>
<font size=2><tt>I designed a quite complex VEE program using VEE 6.02. It runs nicely using
the development environment. It runs as well in production since several
months using the runtime version, however termination / abortion of the
program causes a VEE error 801 with subsequent Dr. Watson; see the screen
dump in the attached pdf document. (The pdf file and the Error801.vee file
are in a zip archive as very often pdf files attached to an e-mail are
corrupted).
</tt></font>
<font size=2><tt>The VEE program contains an initialization StartUp User Object, a MainLoop
User Object and a ShutDown User Function; see attached Error801.vee file.
The MainLoop User Object consists of three UntilBreak loops. One is for
normal operation of subsequent tasks, and the other two are for termination
and abortion.
</tt></font>
<font size=2><tt>The indicated instrument B725 is not called in the ShutDown User Function.
</tt></font>
<font size=2><tt>The error 801 occurs in both cases, i.e. termination (F12) and abortion
(F11).
</tt></font>
<font size=2><tt>Do you have any ideas on what is the reason for the error 801 that occurs
only in the runtime version? I already was in contact with the Agilent
hotline in The Netherlands, but without any success.
</tt></font>
<font size=2><tt>Kind regards
Hans-Joachim Fischer
</tt></font>
<font size=2><tt>------------------------------------------
ESF GmbH
Brennerweg 7
D-89143 Blaubeuren
+49-7344-919693
+49-7344-919691 (fax)
+49-175-40 74 5 74 (GSM)
http://www.esf-gmbh.de
------------------------------------------</tt></font>
You are currently subscribed to vrf as: ramarquardt@ra.rockwell.com
If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</tt></font>
<font size=1 color=red face="sans-serif">|| Attachment clipped: Error801.zip (22734 bytes ) >></font>
---You are currently subscribed to vrf as: rsb@soco.agilent.comTo subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".
</font>
....Rob</font>
Rob Marquardt
USA
414-382-3098
414-382-4820 (FAX)
</font>
</tt></font>
corrupted).
</tt></font>
and abortion.
</tt></font>
</tt></font>
(F11).
</tt></font>
</tt></font>
</tt></font>
ESF GmbH
Brennerweg 7
D-89143 Blaubeuren
+49-7344-919693
