Thanks Barrie,
I don't have the manual yet.
Did your email have a Vee attachment? If so I did not receive a separate
attachment, only the Vee listing as below.
Thanks again,
Ashley
----- Original Message -----
From: "barrie birmingham" <b.birmingham@newi.ac.uk>
To: <ashley@smartsolutions.karoo.co.uk>
Sent: Friday, January 16, 2004 5:10 AM
Subject: TTi1705Ohms
> I'd just use a set of directIO objects with the commands from the manual
for such
> a simple application.
> Try the attached Vee file as a starter (Assuming the DMM is on Com1) (I
think
> the commands are right from memory?!)
> Barrie Birmingham
> (saveFormat "2.3")
> (date "Fri 16/Jan/2004 13:08:25 GMT")
> (veerev "6.01")
> (platform "PC")
> (execMode v6)
> (filterNAN 0)
> (workspaceStackingOrder M)
> (sysconfig
> (iodevice "newInstrument"
> (type Serial)
> (gateway "This host")
> (channel 1)
> (readTerm "
> (fs ",")
> (eol "
> (multiField dataOnly)
> (arrayFormat linear)
> (timeout 5)
> (byteOrder 0)
> (model "")
> (baudRate 9600)
> (charSize 8)
> (stopBits 1)
> (parity off)
> (handshake off)
> (recvBufferSize 4096)))
> (SaveCF no)
> (device 0 ROOTCONTEXT
> (properties
> (trigMode deg)
> (nextID 7)
> (popupTitleText "Untitled")
> (popupMoveable 1))
> (deviceList
> (device 0 IODEVICE
> (properties
> (name "Reset DMM")
> (transactions 1 "WRITE TEXT "*RST" EOL"))
> (implementation
> (iopath "newInstrument")))
> (device 1 IODEVICE
> (properties
> (name "newInstrument ( @ 1)")
> (transactions 1 "WAIT INTERVAL:10"))
> (implementation
> (device 2 IODEVICE
> (properties
> (name "Set to Resistance (Autorange)")
> (transactions 1 "WRITE TEXT "OHMS" EOL"))
> (implementation
> (device 4 TEXTDISPLAY
> (interface
> (input 1
> (name "Data"))))
> (device 5 IODEVICE
> (properties
> (transactions 1 "WAIT INTERVAL:3"))
> (implementation
> (device 6 IODEVICE
> (properties
> (name "Do a sample and return answer")
> (transactions 2 "WRITE TEXT "READ?" EOL" "READ TEXT x REAL64"))
> (interface
> (output 1
> (name "x")
> (optional yes)))
> (implementation
> (configuration
> (connect D0:0 D1:0)
> (connect D1:0 D2:0)
> (connect D5:1 D3:1)
> (connect D2:0 D4:0)
> (connect D4:0 D5:0)))
> (contextCarrier
> (wndRestoredOrigin 2 2)
> (wndRestoredExtent 568 348)
> (wndState max)
> (active detail)
> (detail
> (extent 796 493)
> (anchorPt 0 0)
> (configuration
> (devCarrierFor 0
> (active open)
> (icon
> (extent 69 0)
> (iconImage "io.icn"))
> (open
> (extent 229 74))
> (terminals on)
> (pinCenter 250 100))
> (devCarrierFor 1
> (active open)
> (icon
> (open
> (extent 229 74))
> (terminals on)
> (pinCenter 250 200))
> (devCarrierFor 2
> (active open)
> (icon
> (extent 180 0)
> (open
> (extent 229 74))
> (terminals on)
> (pinCenter 250 310))
> (devCarrierFor 4
> (active open)
> (icon)
> (open
> (extent 121 22))
> (pinCenter 650 410))
> (devCarrierFor 5
> (active open)
> (icon
> (open
> (extent 229 74))
> (terminals on)
> (pinCenter 250 430))
> (devCarrierFor 6
> (active open)
> (icon
> (extent 191 0)
> (open
> (extent 229 74))
> (terminals on)
> (pinCenter 610 240))
> (connect D0:0 D1:0
> (points 2 250 139 250 142))
> (connect D1:0 D2:0
> (points 2 250 239 250 252))
> (connect D5:1 D3:1
> (points 6 757 240 780 240 780 300 570 300 570 410 587 410))
> (connect D2:0 D4:0
> (points 2 250 349 250 372))
> (connect D4:0 D5:0
> (points 6 250 469 250 480 420 480 420 160 610 160 610 182)))
> (stackingOrder 0 3 1 2 4 5))
> (numberFormats
> (realFormat standard)
> (realSigDigits 4)
> (realRadixSpec 4)
> (integerBase decimal))))
Send your favorite VEE example to "VRF-EXAMPLES@agilent.com" for possible inclusion in VEE 7.0!
Thanks again,
Ashley
for such
think
> Barrie Birmingham
> (saveFormat "2.3")
> (veerev "6.01")
> (platform "PC")
> (execMode v6)
> (filterNAN 0)
> (sysconfig
> (type Serial)
> (channel 1)
> (readTerm "
> (fs ",")
> (eol "
> (timeout 5)
> (byteOrder 0)
> (model "")
> (baudRate 9600)
> (charSize 8)
> (stopBits 1)
> (parity off)
> (handshake off)
> (SaveCF no)
> (properties
> (trigMode deg)
> (nextID 7)
> (popupMoveable 1))
> (deviceList
> (device 0 IODEVICE
> (properties
> (name "Reset DMM")
> (implementation
> (device 1 IODEVICE
> (properties
> (implementation
> (device 2 IODEVICE
> (properties
> (implementation
> (interface
> (input 1
> (name "Data"))))
> (device 5 IODEVICE
> (properties
> (implementation
> (device 6 IODEVICE
> (properties
> (interface
> (output 1
> (name "x")
> (optional yes)))
> (implementation
> (configuration
> (connect D0:0 D1:0)
> (connect D1:0 D2:0)
> (connect D5:1 D3:1)
> (connect D2:0 D4:0)
> (contextCarrier
> (wndState max)
> (active detail)
> (detail
> (extent 796 493)
> (anchorPt 0 0)
> (configuration
> (devCarrierFor 0
> (active open)
> (icon
> (extent 69 0)
> (open
> (extent 229 74))
> (terminals on)
> (devCarrierFor 1
> (active open)
> (icon
> (open
> (extent 229 74))
> (terminals on)
> (devCarrierFor 2
> (active open)
> (icon
> (extent 180 0)
> (open
> (extent 229 74))
> (terminals on)
> (devCarrierFor 4
> (active open)
> (icon)
> (open
> (extent 121 22))
> (devCarrierFor 5
> (active open)
> (icon
> (open
> (extent 229 74))
> (terminals on)
> (devCarrierFor 6
> (active open)
> (icon
> (extent 191 0)
> (open
> (extent 229 74))
> (terminals on)
> (connect D0:0 D1:0
> (connect D1:0 D2:0
> (connect D5:1 D3:1
> (connect D2:0 D4:0
> (connect D4:0 D5:0
> (numberFormats
> (realSigDigits 4)
> (realRadixSpec 4)
