I would like to know if anyone has found a way to release a serial port in
Vee (6.01) once it has been communicated to.
What I want to do is:
In VEE
run test program
talk to unit via COM1
(Release COM1)
Launch DOS programming App that uses COM1
Exit DOS app and return control to VEE
talk to unit via COM1 again.
I have not found a method, and I have to exit VEE to run the programming
app.
(yes I can use a second serial port and a switch, but I want to know if I
can release the serial port)
Any help would be much appreciated, even it is to tell me that it is not
possible.
Cheers
John Freriks
Test Engineer
Send your favorite VEE example to "VRF-EXAMPLES@agilent.com" for possible inclusion in VEE 7.0!
In VEE
run test program
(Release COM1)
app.
possible.
Cheers
John Freriks
Test Engineer
'Execute Close'
best regards,
G. Nied
Georg Nied - Software-Development - Hansestr.7 - 51149 Cologne - Germany
Tel: +49 2203 9770915 - Fax: +49 2203 9770924 - eMail:info@gn-software.de
-------- Original Message --------
Subject: [vrf] Releasing Serial Ports (29-Jan-2004 16:51)
To: vrf@agilent.com
> In VEE
> run test program
> (Release COM1)
> app.
> possible.
> Cheers
> John Freriks
> Test Engineer
> You are currently subscribed to vrf as: g.nied@gn-software.de
To: jfreriks@optusnet.com.au
vrf@agilent.com
