"arie.fainbrun" <arief12@netvision.net.il> wrote:
> I have a few programs that have the same user function, the problem is that
> user function has inside it more user function, so when I want to copy it
> To other program, I have to copy all the sub user function. I would like to
> know if there is any option to copy the main user function, or use it in any
> way that
Sounds like a perfect use of libraries.
Put your function and all its associated functions into a library
and just import it into your working programs.
Or copy if you need local copies of some sort, like you want to
make changes to them.
Stan
Send your favorite VEE example to "VRF-EXAMPLES@agilent.com" for possible inclusion in VEE 7.0!
> way that
Stan
