<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"><HTML><HEAD><META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=us-ascii"><TITLE>Message</TITLE><META content="MSHTML 6.00.2800.1264" name=GENERATOR></HEAD><BODY><DIV><SPAN class=727313006-20012004><FONT face=Arial size=2>All,</FONT></SPAN></DIV><DIV><SPAN class=727313006-20012004><FONT face=Arial size=2></FONT></SPAN> </DIV><DIV><SPAN class=727313006-20012004><FONT face=Arial size=2>I'm doing some socket based communications between systems and sometimes, the remote system isn't responding (late night backups, reboots, offline, etc) and the call times out waiting for data. Normally, this is fine, since I set a time-out limit and trap the errors. Sometimes, however, a socket call will do this once, get an error, trap the error, and then the COMPUTER system (not just VEE) will be unable to use the port again (not sure if more than just the one port) until I halt the VEE app and exit the program. Any ideas what could be causing such a hang-up? I'm using the internal VEE socket calls...</FONT></SPAN></DIV><DIV><SPAN class=727313006-20012004><FONT face=Arial size=2></FONT></SPAN> </DIV><DIV><SPAN class=727313006-20012004><FONT face=Arial size=2>Thanks!</FONT></SPAN></DIV><DIV><SPAN class=727313006-20012004><FONT face=Arial size=2></FONT></SPAN> </DIV><DIV><SPAN class=727313006-20012004><FONT face=Arial size=2>Joshua Posamentier</FONT></SPAN></DIV>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".<BR>Send your favorite VEE example to "VRF-EXAMPLES@agilent.com" for possible inclusion in VEE 7.0!</BODY></HTML>
