"Andersen Dave-P26278 <Dave.Andersen@gdds.com> wrote:
> Hi
> We are looking into a test system where the vendor has used CORBA to build
> their software around. I want to be able to use VEE to control/interface with
> their test system as well as our UUT and other test equipment. Has anyone out
> there used VEE to interface with CORBA? What gotcha's did you run across?
> The vendor is offering to code up some activeX wrappers I can use. Would this
> be a better way to go?
If you have ActiveX capability go for it. CORBA has been out there
a very long time but it never really got adopted except in small niches,
so getting into the widely accepted ActiveX will be much better.
Stan
> Hi
Stan
We are looking into a test system where the vendor has used CORBA to build their software around. I want to be able to use VEE to control/interface with their test system as well as our UUT and other test equipment. Has anyone out there used VEE to interface with CORBA? What gotcha's did you run across? The vendor is offering to code up some activeX wrappers I can use. Would this be a better way to go?
Dave Andersen
Software Engineer
Communication Systems Division
General Dynamics C4 Systems
email: Dave.Andersen@gdds.com
