Bernie,
as far as I know (and only experience can tell it as documentation is
not available on that matter by Agilent) you have to do the following:
1) configure serial interface in HP I/O Libraries (outside VEE) and keep
note of serial address of the port you intend to use (1 usually): you have
to use the parameters (baud rate, parity, ...) of your balance
2) configure with the same parameters the instrument manager: check also
the separators (EOL) needed by your balance and set port address (1 for
example)
3) before the first command you want to send to your balance send an
"EXECUTE CLOSE" command on the first line of direct i/o
4) now you should be able to communicate (write and read) with your port:
you can also check with I/O monitor object all the byte you're exchanging
in both directions with your port
Have a nice day,
Martino
Ing. MARTINO ROSIN
Calearo Antenne Srl
Via Bacchiglione, 49
36033 ISOLA VICENTINA (VI)
E-mail: martinorosin@calearo.com
