Hello Thomas,
you can just download the driver from the ADN site. I will give you the link
here:
ADN->Downloads->Sofware: VEE PRO->VEE Pro Archive.
You have to download the file "VEE PeekPoke DLL For Windows 95 & Windows NT
(Obsolete) Version Obsolete 2000.04.20, April 20, 2000, 98KB, .exe. This
self-extracting archive contains files for using and building an I/O-port
PeekPoke".
It is not easy to find, but the path above should help you getting the DLL
and the driver.
Best regards,
Martin Alles
> -----Ursprngliche Nachricht-----
> Von: Thomas.Mitchell@Autoliv.com [SMTP:Thomas.Mitchell@Autoliv.com]
> Gesendet am: Dienstag, 17. Februar 2004 19:13
> An: Martin.Alles@hno.atmel.com
> Betreff: Re: [vrf] AW: parallel port, [vrf] Printer port access
> Hi martin, I've looked at the Agilent site and I can't find those 2 dll's.
> Would you happen to have those files and could you send them to me?
> Thanks
> Tom
> Martin.Alles@hno.
> atmel.com To: VRF
> <vrf@agilent.com>
> cc: vrf@agilent.com
> 02/17/2004 09:46 Subject: [vrf] AW:
> AM
> Please respond to
> Martin.Alles
> Hello,
> I included a program which sends data to the data byte and the control
> byte
> of the printer port lpt1. The program counts from 0 to 15 and sends this
> data to the two bytes. This program runs on Windows NT4 and on Windows2000
> with VEE5.0. The program uses the peekpoke utility, which could be
> retrieved
> also from the Agilent website, if I remember correctly, there was a
> posting
> not so much time ago (ftp-link).
> The peekpoke utility contains a dll with a header file and also an
> utility,
> which launches a small driver/application. This application gives direct
> access to the memory, i.e. the port address in this case. This application
> has to been started before the program runs, otherwise it will not work.
> I have not used the InpOut32 dll up to now, therefore I can not answer the
> questions to this software.
> Hope this helps!
> Best regards,
> Martin
> <<lpt_test.vee>>
> > Von: Luigi Cervato [SMTP:LuigiCervato@calearo.com]
> > Gesendet am: Montag, 16. Februar 2004 17:40
> > Betreff: Rif: AW: [vrf] parallel port
> > Hi. Thank you for your answer.
> > Usually I use the library you can find in attach.
> > Could you send me some example for a better understanding?
> > How do you call the function peekepoke?
> > Do you have a list for function calling?
> > Thank you!
> > Bye.
> > Luigi
> > (See attached file: InpOut32.h)(See attached file: inpout32.dll)
> > Ing. Luigi Cervato
> > R&D Department
> > CALEARO ANTENNE SRL
> > Via Bacchiglione, 49
> > 36033 Isola Vicentina (Vi) - Italy
> > Tel: +39 0444 901 301 (centralino)
> > Fax: +39 0444 901 375
> > E-mail: LuigiCervato@calearo.com << Datei: InpOut32.h >> << Datei:
> > inpout32.dll >>
> (See attached file: lpt_test.vee)---
> You are currently subscribed to vrf as: Thomas.Mitchell@Autoliv.com
> Send your favorite VEE example to "VRF-EXAMPLES@agilent.com" for possible
> inclusion in VEE 7.0!
> << Datei: lpt_test.vee >>
Send your favorite VEE example to "VRF-EXAMPLES@agilent.com" for possible inclusion in VEE 7.0!
here:
PeekPoke".
and the driver.
Best regards,
Martin Alles
> Thanks
> Tom
> Martin.Alles@hno.
> atmel.com To: VRF
> <vrf@agilent.com>
> cc: vrf@agilent.com
> AM
> Please respond to
> Martin.Alles
> Hello,
> byte
> retrieved
> posting
> utility,
> Hope this helps!
> Best regards,
> Martin
> <<lpt_test.vee>>
> > Thank you!
> > Bye.
> > Luigi
> > Ing. Luigi Cervato
> > R&D Department
> > CALEARO ANTENNE SRL
> > inpout32.dll >>
Les.Hammer@CompleteTest.com
