Hi All
I have an application that uses VBScripting internally
and I would like to control it via ActiveX Automation.
Mostly working fine but I seem to have found a stumbling
block when it comes to Array values
In particular script excerpts include:
Dim oHfssApp
Dim oDesktop
Dim oProject
these guys become Declare Variable objects with no issues
Set oHfssApp = CreateObject("AnsoftHfss.HfssScriptInterface")
Set oDesktop = oHfssApp.GetAppDesktop()
these guys copy directly to a formula- again with no issues
oProject.InsertDesign "HFSS", "HFSSModel1", "DrivenModal", ""
this becomes oProject.InsertDesign("HFSS",HFSSMODEL1","DrivenModal","")
again- no issues
Now comes the one with array parameter (below). I've tried several
ideas to no avail. SO- what's the VEE equivalent for these calls?
oEditor.CreateBox Array("NAME:BoxParameters", "XPosition:=", "0mm", "YPosition:=", _
"0mm", "ZPosition:=", "0mm", "XSize:=", "2.6mm", "YSize:=", "0.6mm", "ZSize:=", _
"0.6mm"), Array("NAME:Attributes", "Name:=", "Box1", "Flags:=", "", "Color:=", _
"(132 132 193)", "Transparency:=", 0, "PartCoordinateSystem:=", "Global", "MaterialName:=", _
"vacuum", "SolveInside:=", true)
oDesign.ChangeProperty Array("NAME:AllTabs", Array("NAME:Geometry3DCmdTab", Array("NAME:PropServers", _
"LocalVariables"), Array("NAME:NewProps", Array("NAME:Lz", "PropType:=", "VariableProp", "UserDef:=", _
true, "Value:=", "1"))))
probably something very simple I'm overlooking
THANKS
Stan
Dim oHfssApp
Dim oDesktop
Dim oProject
again- no issues
THANKS
Stan
worked. Hmmm... cool feature.
-SHAWN-
