Hi Scott et al.,
Thanks for the reply. I kind of thought this might be the case with the
to/from socket thing. I do have it working with the UDP sockets in VEE 6.0
but with the ActiveX calls to MSWinsock. We were thinking of testing
communications via TCP anyway since UDP doesn't have error checking. If
anyone is interested in seeing how I did it with ActiveX/UDP let me know and
I'll send you a copy of my code (it's really small and simple).
Best,
Karen
From: BAYES,SCOTT (A-Loveland,ex1) [mailto:scott_bayes@agilent.com]
Sent: Thursday, December 04, 2003 7:30 PM
To: VRF
Cc: PDL-LISTS,VRF (A-Lists,unix1)
Subject: [vrf] RE: to/from socket
Hi Karen and vrf,
As far as I know, VEE cannot handle UDP sockets, only TCP. I think you're
going to need to use TCP as the base protocol in order for VEE to
participate.
Best regards,
Scott Bayes
Software Technical Support
Agilent Technologies, Inc.
815 14th Street S.W.
Loveland, CO, U.S.A. 80537
970 679 3799 Tel
970 635 6867 Fax
> From: KB Werner [mailto:kbwerner@fcrao1.astro.umass.edu]
> Sent: Thursday, December 04, 2003 12:13 PM
> To: VRF
> Subject: [vrf] to/from socket
> Hello All,
> I'm trying to use the to/from socket object to send and
> receive data from a
> remote machine. I set the "connect" host to the proper value
> (i.e., 5500),
> and enter the correct ip address of the remote computer.
> Then I set the
> "bind" host (my computer) to 5500, and my ip address. I then
> try to execute
> a simple "write text" operation, but it doesn't find the remote host.
> I know all the hardware along the way is working because we
> were able to
> communicate (slightly flakey, but it worked a few times) via ActiveX
> (MSWinsock). We just can't get it to work using the to/from
> socket object.
> We are using UDP, not TCP - is that the problem?
> Thanks much.
> Karen
> Karen Bourque Werner
> Research Assistant - FCRAO
> Department of Astronomy
> 726 Lederle Graduate Research Center
> University of Massachusetts
> Amherst, MA 01003
> phone: 413.545.9603
> phax: 413.545.4223
> You are currently subscribed to vrf as: scott_bayes@agilent.com
You are currently subscribed to vrf as: kbwerner@fcrao1.astro.umass.edu
I'm trying to use the to/from socket object to send and receive data from a
remote machine. I set the "connect" host to the proper value (i.e., 5500),
and enter the correct ip address of the remote computer. Then I set the
"bind" host (my computer) to 5500, and my ip address. I then try to execute
I know all the hardware along the way is working because we were able to
(MSWinsock). We just can't get it to work using the to/from socket object.
Thanks much.
Karen
Amherst, MA 01003
phone: 413.545.9603
phax: 413.545.4223
