Hello all,
Iam new to vee pro, i want to learn it and i need to
develop control system which can measure the currents
from the 8 relays and the 8 power sources which are
measureing the range of 0-6.5kv. and plot the graph .
can u please help me how to represent them using the
software.
eagerly waiting for the reply
__________________________________
Do you Yahoo!?
Protect your identity with Yahoo! Mail AddressGuard
http://antispam.yahoo.com/whatsnewfree
software.
Do you Yahoo!?
> software.
VEE Pro, by itself, can not measure anything.
First you need some instruments - One that can
take 6.5 kV. Do you have the instrument already?
Does it have GPIB, RS232, LAN or USB insterface?
Does it have a programming language? These are things
that you must find first.
Then find if the instrument has a driver - Plug&Play,
IVI, VEE Classic. Or you may be able to use Direct IO.
Again, without knowing what instrument you have, we can not
help.
Once you have the instrument programming interface set up,
the rest is easy. VEE has an XY Trace under Display.
Les Hammer
Partner
Complete Test
720 SW 14th St.
Loveland, CO. 80537
Les.Hammer@CompleteTest.com
