> According to your statement that you need one data Acquisition/sw
> unit(HP37970A) and 20 ch.actuator/gp swich card(34903A).
Except that he previously said that he needed 6.5kV.
Since other experts have responded that they can help
him with the Milhaus card, I'll drop out of the discussion.
Les
http://www.arcelect.com/rs485.htm
From: McGlynn, Richard [mailto:richard.mcglynn@baesystems.com]
Sent: Tuesday, November 11, 2003 9:59 AM
To: VRF
Subject: [vrf] RE: 16-port serial PCI
Hi All,
I've recently installed an NI RS485 card and the Agilent Vee I/O library
that includes the SICL. I've also successfully performed a loopback test
with COM port 4 by jumpering pins 5 to 9 and 4to 8. I'm trying to understand
the difference between RS232 and RS 485. The interface seems to be running
just fine in VEE but I thought the protocol was totally different for RS 485
as opposed to RS232. Is this a hardware driven difference or this something
that is taken into account by the drivers contained in the SICL I/O library?
Rich McGlynn
Sr. Test Design Engineer
BAE SYSTEMS
Richard.McGlynn@baesystems.com
phone: (603) 885-7427
From: "Martn Castillejos, Juan Carlos" [mailto:jcmartin@indra.es]
Sent: Tuesday, November 11, 2003 10:19 AM
To: VRF
Be careful of:
a) Update the SICL with new ports.
b) Check that new ports in the OS (COMx) get the same logial unit in SICL
(click into the com port and use edit button). Take into account that there
are some addresses that are reserved and they are not allowed to be used (If
I rmember good 14, 15). Due to that I use to install COM ports from 21 to 39
for RS422-485 and for 41 to 99 for RS232.
regards,
> -----Mensaje original-----
> De: John Graves [mailto:john.graves@recreation.bombardier.com]
> Enviado el: lunes, 10 de noviembre de 2003 20:14
> Para: VRF
> Asunto: [vrf] 16-port serial PCI
> I am proposing a question for the best way to interface with
> my Rockport PCI 16-port serial card and interface.
> (Comtrol Rocket Port PCI card #95750-8 and interface# 97100-9)
> It has been working just fine with using 10 ports, i have
> added 5 additional items to communicate with and now I have
> it has problems. Errors out and tells me the port i am
> trying to access has not been set up,
> but it is in the I/O configuration. And it gives me no errors there.
> Ideas or suggestions
> thanks
> John K. Graves - Test Engineer
> Boats and Outboard Engines Division
> Bombardier Recreational Products
> 329 Hallberg Street
> Delavan, WI 53115
> You are currently subscribed to vrf as: jcmartin@indra.es
Este correo electrnico y, en su caso, cualquier fichero anexo al mismo,
contiene informacin de carcter confidencial exclusivamente dirigida a su
destinatario o destinatarios. Queda prohibida su divulgacin, copia o
distribucin a terceros sin la previa autorizacin escrita de Indra. En el
caso de haber recibido este correo electrnico por error, se ruega notificar
inmediatamente esta circunstancia mediante reenvo a la direccin
electrnica del remitente.
The information in this e-mail and in any attachments is confidential and
solely for the attention and use of the named addressee(s). You are hereby
notified that any dissemination, distribution or copy of this communication
is prohibited without the prior written consent of Indra. If you have
received this communication in error, please, notify the sender by reply
e-mail
You are currently subscribed to vrf as: richard.mcglynn@baesystems.com
You are currently subscribed to vrf as: Larry.Hartley@L-3com.com
