Hello David.
You could use a Text Constant added to a panel. You could have a huge
number of items, but selecting the text to copy would be a problem. If only
Ctrl+A (select all) worked here. You could add a button to dump all or part
of the text to a text file.
You'd need to use the concatenator to add items to the existing list.
Hope this helps, as a start.
Regards
Andrew F
Genesys IBS
----- Original Message -----
To: "VRF" <vrf@agilent.com>
Sent: Wednesday, December 10, 2003 2:22 PM
Subject: [vrf] Creating a datalogging window
> Hi all,
> I have written a 'Front end' for displaying/datalogging test results.
This
> has been used successfully for many years. However, I find that using the
> 'Logging Alphanumeric' in a panel, to display the datalogs, has
> limitations. I can't minimise or re-size the window and I can't
copy/paste
> data should it be required during de-bug.
> I would like to create a new Notepad-style window for datalogging. Where
> do I start?
> Regards
> David Watling
> You are currently subscribed to vrf as: AndrewF@genesysibs.com
Regards
Andrew F
Genesys IBS
> Hi all,
This
copy/paste
> do I start?
> Regards
> David Watling
I have written a 'Front end' for displaying/datalogging test results. This
limitations. I can't minimise or re-size the window and I can't copy/paste
do I start?
Regards
David Watling
