Hello All,
I'm trying to use the to/from socket object to send and receive data from a
remote machine. I set the "connect" host to the proper value (i.e., 5500),
and enter the correct ip address of the remote computer. Then I set the
"bind" host (my computer) to 5500, and my ip address. I then try to execute
a simple "write text" operation, but it doesn't find the remote host.
I know all the hardware along the way is working because we were able to
communicate (slightly flakey, but it worked a few times) via ActiveX
(MSWinsock). We just can't get it to work using the to/from socket object.
We are using UDP, not TCP - is that the problem?
Thanks much.
Karen
Karen Bourque Werner
Research Assistant - FCRAO
Department of Astronomy
726 Lederle Graduate Research Center
University of Massachusetts
Amherst, MA 01003
phone: 413.545.9603
phax: 413.545.4223
Thanks much.
Karen
Amherst, MA 01003
phone: 413.545.9603
phax: 413.545.4223
