<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2//EN"><HTML><HEAD><META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=iso-8859-1"><META NAME="Generator" CONTENT="MS Exchange Server version 5.5.2653.12"><TITLE>fetch1?</TITLE></HEAD><BODY><P><FONT FACE="Arial">Im trying to do a TOTALIZE measurement with a E1420B CounterTimer. The manual states that you must use the INITiate and FETch commands, verses the READ to get the readings out of the buffer. I am setting the C/T up with no errors, at least it is reporting no errors, and I can perform a FETC1? command which should fetch the data. </FONT></P><P><FONT FACE="Arial">My question: What is the next command I use to get the data out of my direct I/O object? When I use the READ command I simply put READ X in my direct I/O object and the data is at the output pin X of that object. </FONT></P><P><FONT FACE="Arial">As always, thanks in advance</FONT><BR><FONT FACE="Arial">Ross</FONT></P>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</BODY></HTML>
<b><span style='font-weight:bold'>Sent:</span></b> Thursday, December 11, 20033:42 PM
<b><span style='font-weight:bold'>To:</span></b> VRF
<b><span style='font-weight:bold'>Subject:</span></b> [vrf] fetch1?</span></font><o:p></o:p></p></div><p class=MsoNormal><font size=3 face="Times New Roman"><span style='font-size:12.0pt'><o:p> </o:p></span></font></p><p><font size=3 face=Arial><span style='font-size:12.0pt;font-family:Arial'>Imtrying to do a TOTALIZE measurement with a E1420B CounterTimer. Themanual states that you must use the INITiate and FETch commands, verses theREAD to get the readings out of the buffer. I am setting the C/T up withno errors, at least it is reporting no errors, and I can perform a FETC1?command which should fetch the data. </span></font><o:p></o:p></p><p><font size=3 face=Arial><span style='font-size:12.0pt;font-family:Arial'>Myquestion: What is the next command I use to get the data out of my directI/O object? When I use the READ command I simply put READ X in my directI/O object and the data is at the output pin X of that object. </span></font><o:p></o:p></p><p><font size=3 face=Arial><span style='font-size:12.0pt;font-family:Arial'>Asalways, thanks in advance</span></font>
<font face=Arial><span style='font-family:Arial'>Ross</span></font> <o:p></o:p></p><p class=MsoNormal><font size=3 face="Times New Roman"><span style='font-size:12.0pt'>---
You are currently subscribed to vrf as: jay.johannes@completetest.com
To subscribe send a blank email to"join-vrf@it.lists.it.agilent.com".
To unsubscribe send a blank email to"leave-vrf@it.lists.it.agilent.com".
If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".<o:p></o:p></span></font></p></div></div>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</BODY></html>
