Robert (and all) -
>> If the CallableVeeServer is started by a VeeRuntime 6.1 only the scalar
>> outputs contain data. The 1Dim outputs have the datatype 8 = nil, which
>> means they are not pinged.
> Actually, Mike Groves recently detailed what appears to be a
> propagation bug in 6, and it looks like Agilent agrees.
Sorry guys, I messed up. The originator was actually Christian Wienhold on
10/15 with the subject "VEE 6 bug presentation". It details a propogation
problem and I got Christian and Mike's messages mixed up as Mike's was fresh
in mind.
Robert: did you find out what's going on?
-SHAWN-
in mind.
-SHAWN-
I wrote a function in Vee Pro 6.1 and want to call them from a C++
programm on another computer. Some outputs of the function are Scalar
Real64 and some are 1Dim Real64.
If the CallableVeeServer is started by the Vee Pro 6.1 Environment,
everything works fine: all outputs have data, which can passed to the
C++ prog.
Has anybody else this problem or a solution? It looks like an
incompatibility between development environment and runtime environment.
Unfortunately I cannot examine what happens because the debug mode does
not work in runtime environment.
I appreciate YOUR help!
Thanx in advance!
Rob
__________________________________________________________________
Robert Hemp
RST Raumfahrt Systemtechnik GmbH
Bahnhofstr. 108
D-88682 Salem
Tel: +49-7553-827915
Fax: +49-7553-827911
eMail: r.hemp@rst-group.biz
Web: www.rst-group.biz
