Saw it the other way round:
We had severe timing problems last year using LabVIEW 6 with an elderly PCI
AD/DA board - with VEE 4/6 and .dll, it was running full speed according to
datasheet.
Didn't get any further useful information on that, but you may check if
enough memory is available and if your swapping disk is slow.
Best regards,
Stefan
Baranski, Detlef schrieb:
> Hi list,
> before i go too deep into details, just the simple question- Is VEE slower
> than LAbview if you use an IO-Card ?
> We do have an old IO-Card which is called via .dll
> The test data access via VEE gets about 100 Values , via Visual BAsic and
> Labview about 1000.
> Is VEE in principle slower than the others in that case ?
> Otherwise i can go in more detail ...-
> It on a 500 MHz machine.
> Thanks for help,.
> detlef
> This message and any attachments are confidential, for the exclusive use of
> the addressee and may be legally privileged. Any other distribution, use or
> reproduction is unauthorised and prohibited. If you have received this
> message in error, please notify the sender immediately and delete the
> message from your system.
> Visit our internet site at http://www.pilkington.com
> You are currently subscribed to vrf as: stefan.paulick@urbeli.com
> If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".
Mit freundlichen Gren / With kindest regards
Stefan Paulick
http://www.urbeli.com
datasheet.
Best regards,
Stefan
> Hi list,
> Labview about 1000.
> Thanks for help,.
> detlef
Stefan Paulick
Labview about 1000.
Thanks for help,.
detlef
