<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"><HTML xmlns="http://www.w3.org/TR/REC-html40" xmlns:o = "urn:schemas-microsoft-com:office:office" xmlns:w = "urn:schemas-microsoft-com:office:word" xmlns:st1 = "urn:schemas-microsoft-com:office:smarttags"><HEAD><META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=US-ASCII"><META content=Word.Document name=ProgId><META content="MSHTML 5.50.4522.1800" name=GENERATOR><META content="Microsoft Word 10" name=Originator><LINK href="cid:filelist.xml@01C41AEA.01BF24F0" rel=File-List><o:SmartTagType name="country-region" namespaceuri="urn:schemas-microsoft-com:office:smarttags"></o:SmartTagType><o:SmartTagType name="place" namespaceuri="urn:schemas-microsoft-com:office:smarttags"></o:SmartTagType><!--[if gte mso 9]><xml> <o:OfficeDocumentSettings> <o:DoNotRelyOnCSS/> </o:OfficeDocumentSettings></xml><![endif]--><!--[if gte mso 9]><xml> <w:WordDocument> <w:SpellingState>Clean</w:SpellingState> <w:GrammarState>Clean</w:GrammarState> <w:DocumentKind>DocumentEmail</w:DocumentKind> <w:HyphenationZone>14</w:HyphenationZone> <w:EnvelopeVis/> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument></xml><![endif]--><!--[if !mso]><STYLE>st1:* { BEHAVIOR: url(#default#ieooui)}</STYLE><![endif]--><STYLE>@page Section1 {size: 595.3pt 841.9pt; margin: 70.85pt 2.0cm 2.0cm 2.0cm; mso-header-margin: 35.4pt; mso-footer-margin: 35.4pt; mso-paper-source: 0; }P.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman"; mso-style-parent: ""; mso-pagination: widow-orphan; mso-fareast-font-family: "Times New Roman"}LI.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman"; mso-style-parent: ""; mso-pagination: widow-orphan; mso-fareast-font-family: "Times New Roman"}DIV.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman"; mso-style-parent: ""; mso-pagination: widow-orphan; mso-fareast-font-family: "Times New Roman"}A:link { COLOR: blue; TEXT-DECORATION: underline; text-underline: single}SPAN.MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline; text-underline: single}A:visited { COLOR: purple; TEXT-DECORATION: underline; text-underline: single}SPAN.MsoHyperlinkFollowed { COLOR: purple; TEXT-DECORATION: underline; text-underline: single}SPAN.StileMessaggioDiPostaElettronica17 { COLOR: windowtext; FONT-FAMILY: Arial; mso-style-type: personal-compose; mso-style-noshow: yes; mso-ansi-font-size: 10.0pt; mso-bidi-font-size: 10.0pt; mso-ascii-font-family: Arial; mso-hansi-font-family: Arial; mso-bidi-font-family: Arial}SPAN.GramE { mso-style-name: ""; mso-gram-e: yes}DIV.Section1 { page: Section1}</STYLE><!--[if gte mso 10]><style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabella normale"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}</style><![endif]--></HEAD><BODY lang=IT style="tab-interval: 35.4pt" vLink=purple link=blue><DIV><SPAN class=531465908-06042004><FONT face=Arial color=#0000ff size=2>Daniele,</FONT></SPAN></DIV><DIV><SPAN class=531465908-06042004><FONT face=Arial color=#0000ff size=2>Try the PLOT command. According to the HP 8590 E-Series and L-Series Programmer’s Guide, the PLOT command i<SPAN class=531465908-06042004><FONT face=Arial color=#0000ff size=2>nitiates a plotter output of the screen data to the remote interface.</FONT></SPAN></FONT></SPAN></DIV><DIV><SPAN class=531465908-06042004><FONT face=Arial color=#0000ff size=2><SPAN class=531465908-06042004>Here's an extract from the Programmer’s Guide:</SPAN></FONT></SPAN></DIV><DIV><SPAN class=531465908-06042004><FONT face=Arial color=#0000ff size=2><SPAN class=531465908-06042004></SPAN></FONT></SPAN> </DIV><DIV><SPAN class=531465908-06042004><FONT face=Arial color=#0000ff size=2><SPAN class=531465908-06042004>"The PLOT command transfers the trace data, graticule, and annotation of the spectrum<BR>analyzer screen to a plotter via the spectrum analyzer interface (softkey labels excluded). The<BR>data is transferred in ASCII, HPGL format.<BR>When using the PLOT command, the scaling points (Plx, Ply; P2x, P2y) can be specified.<BR>These scaling points specify the (x,y) coordinates, which determine the size of the plot.<BR>(Plx,Ply) refers to the lower-left plotter coordinates. (P2x,P2y) refers to the upper-right<BR>plotter coordinates."<BR></SPAN></FONT></SPAN><SPAN class=531465908-06042004><FONT face=Arial color=#0000ff size=2><SPAN class=531465908-06042004></SPAN></FONT></SPAN></DIV><DIV><SPAN class=531465908-06042004><FONT face=Arial color=#0000ff size=2><SPAN class=531465908-06042004>You will then need to find a utility that can convert HPGL to something that windows can display.</SPAN></FONT></SPAN></DIV><DIV><SPAN class=531465908-06042004><FONT face=Arial color=#0000ff size=2><SPAN class=531465908-06042004>Hope that helps.</SPAN></FONT></SPAN></DIV><DIV><SPAN class=531465908-06042004><FONT face=Arial color=#0000ff size=2><SPAN class=531465908-06042004>Regards,</SPAN></FONT></SPAN></DIV><DIV><SPAN class=531465908-06042004><FONT face=Arial color=#0000ff size=2><SPAN class=531465908-06042004>Warren</SPAN></FONT></SPAN></DIV><DIV><SPAN class=531465908-06042004><FONT face=Arial color=#0000ff size=2><SPAN class=531465908-06042004></SPAN></FONT></SPAN> </DIV><DIV><SPAN class=531465908-06042004><FONT face=Arial color=#0000ff size=2><SPAN class=531465908-06042004></SPAN> </DIV><DIV><BR></FONT></SPAN><FONT face=Tahoma size=2>-----Original Message-----<BR><B>From:</B> Daniele Carnevale [mailto:d.carnevale@dmtonline.com]<BR><B>Sent:</B> 05 April 2004 07:43<BR><B>To:</B> VRF<BR><B>Subject:</B> [vrf] Screen Capture for Spectrum Analyzers HP 856X & HP 859X<BR><BR></DIV></FONT><BLOCKQUOTE> <DIV class=Section1> <P class=MsoNormal><FONT face=Arial size=2><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">Hi VRF,<o:p></o:p></SPAN></FONT></P> <P class=MsoNormal><FONT face=Arial size=2><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><SPAN style="mso-tab-count: 1"> </SPAN></SPAN></FONT><FONT face=Arial size=2><SPAN lang=EN-GB style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-ansi-language: EN-GB">the question I’m gonna ask you could look really silly but I’m quite new to the Test&Measures world, so I hope you’ll excuse me.<o:p></o:p></SPAN></FONT></P> <P class=MsoNormal><FONT face=Arial size=2><SPAN lang=EN-GB style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-ansi-language: EN-GB">Can I capture the screen in a standard format (like PCX or something similar) via the Direct I/O for the Spectrum Analyzers in the subject?<o:p></o:p></SPAN></FONT></P> <P class=MsoNormal><FONT face=Arial size=2><SPAN lang=EN-GB style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-ansi-language: EN-GB">And, if there’s no a way to do that, how can I collect the screen information (the spectrum shape) and compile an excel sheet (with the Xs and the Ys)?<o:p></o:p></SPAN></FONT></P> <P class=MsoNormal><FONT face=Arial size=2><SPAN lang=EN-GB style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-ansi-language: EN-GB"><o:p> </o:p></SPAN></FONT></P> <P class=MsoNormal><FONT face=Arial size=2><SPAN lang=EN-GB style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-ansi-language: EN-GB">Thank you very much.<o:p></o:p></SPAN></FONT></P> <P class=MsoNormal><FONT face=Arial size=2><SPAN lang=EN-GB style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-ansi-language: EN-GB"><o:p> </o:p></SPAN></FONT></P> <P class=MsoNormal><FONT face=Arial size=2><SPAN lang=EN-GB style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-ansi-language: EN-GB"><o:p> </o:p></SPAN></FONT></P> <P class=MsoNormal><FONT face=Arial size=2><SPAN lang=EN-GB style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-ansi-language: EN-GB"><o:p> </o:p></SPAN></FONT></P> <P class=MsoNormal><FONT face=Arial size=2><SPAN lang=EN-GB style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-ansi-language: EN-GB">Regards,<o:p></o:p></SPAN></FONT></P> <P class=MsoNormal><FONT face=Arial size=2><SPAN lang=EN-GB style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-ansi-language: EN-GB"><o:p> </o:p></SPAN></FONT></P> <P class=MsoNormal><FONT face=Arial size=2><SPAN lang=EN-GB style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-ansi-language: EN-GB">Daniele Carnevale<o:p></o:p></SPAN></FONT></P> <P class=MsoNormal><FONT face=Arial size=2><SPAN lang=EN-GB style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-ansi-language: EN-GB">R&D Software Developer<o:p></o:p></SPAN></FONT></P> <P class=MsoNormal><SPAN class=GramE><FONT face=Arial size=2><SPAN lang=EN-GB style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-ansi-language: EN-GB">DMT Group S.p.A.</SPAN></FONT></SPAN><FONT face=Arial size=2><SPAN lang=EN-GB style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-ansi-language: EN-GB"><o:p></o:p></SPAN></FONT></P> <P class=MsoNormal><FONT face=Arial size=2><SPAN lang=EN-GB style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-ansi-language: EN-GB">Via Zanella 21<o:p></o:p></SPAN></FONT></P> <P class=MsoNormal><FONT face=Arial size=2><SPAN lang=EN-GB style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-ansi-language: EN-GB">20035 Lissone (MI)<o:p></o:p></SPAN></FONT></P> <P class=MsoNormal><st1:country-region><st1:place><FONT face=Arial size=2><SPAN lang=EN-GB style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-ansi-language: EN-GB">Italy</SPAN></FONT></st1:place></st1:country-region><FONT face=Arial size=2><SPAN lang=EN-GB style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-ansi-language: EN-GB"><o:p></o:p></SPAN></FONT></P> <P class=MsoNormal><FONT face=Arial size=2><SPAN lang=EN-GB style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-ansi-language: EN-GB"><A href="http://www.dmtonline.com/">www.dmtonline.com</A><o:p></o:p></SPAN></FONT></P> <DIV style="BORDER-RIGHT: medium none; PADDING-RIGHT: 0cm; BORDER-TOP: medium none; PADDING-LEFT: 0cm; PADDING-BOTTOM: 1pt; BORDER-LEFT: medium none; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; mso-border-bottom-alt: solid windowtext .75pt"> <P class=MsoNormal style="BORDER-RIGHT: medium none; PADDING-RIGHT: 0cm; BORDER-TOP: medium none; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: medium none; PADDING-TOP: 0cm; BORDER-BOTTOM: medium none; mso-border-bottom-alt: solid windowtext .75pt; mso-padding-alt: 0cm 0cm 1.0pt 0cm"><FONT face=Arial size=2><SPAN lang=EN-GB style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-ansi-language: EN-GB"><o:p> </o:p></SPAN></FONT></P></DIV> <P class=MsoNormal><FONT face=Arial size=2><SPAN lang=EN-GB style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-ansi-language: EN-GB"><o:p> </o:p></SPAN></FONT></P></DIV>---<BR>You are currently subscribed to vrf as: Warren.Pickles@tycoelectronics.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". </BLOCKQUOTE>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</BODY></HTML>
I don't know how to capture the screen in a standard format.
However, you can download traces of Spectrum Analyzers because
there exists Panel Drivers for HP 856X & HP 859X.
Data Output Terminals "TRA_DATA" and "TRB_DATA" of theses
Panel Drivers will output Magnitude Spectrum of Trace_A or Trace_B
which is easily displayed with the help of
"Magnitude Spectrum" Object.
And about how to create an Excel Chart, please take a look at
an example program Excel97Graph.vee which is in the next folder;
C:Program FilesAgilentVEE Pro 6.XexamplesActiveXAutomation.
FUKUI Yutaka
* $BJ!0f!!K-!J (BFUKUI Yutaka)
* E-Mail: fukui.yutaka@jp.fujitsu.com
* $BIY;NDL3t<02q<R!!@n:j9)>l (B
* $B$b$N$E$/$j?d?JKIt!&@8;:5;=Q3+H/E}3gIt!K7WB,@_Hw3+H/It (B
* $B7WB,@_Hw3+H/It (BHomePage http://www.psl.fujitsu.co.jp/htd2/ksk/
* $B@n:j;TCf866h>e>.EDCf#4 (B- $B#1 (B- $B#1!!M9JXHV9f!' (B211-8588
* TEL $B!!30@~ (B 044-754-3657, $B!!Fb@~ (B 711-3-1966,7
* FAX $B!!30@~ (B 044-754-3509, $B!!Fb@~ (B 711-3-5359
