Hello from Gregg C Levine
Finally a question I can answer. You asked:
> With win98 I get "SendKeys" is not a member of the referenced
ActiveX
> component
> any ides
> which OCX does it invoke ?
It so happens that the Windows Scripting Shell product was introduced
about the same time they introduced OEM SR2. Check to see which
version your running. There should be an update sitting on the
Scripting subsection of the MSDN site. Basically its the same as the
VBScript stuff that they introduced, and then depreciated the use of,
for doing active scripting on HTML pages. (And ASP pages.)
Gregg C Levine hansolofalcon@worldnet.att.net
"The Force will be with you...Always." Obi-Wan Kenobi
"Use the Force, Luke." Obi-Wan Kenobi
> -----Original Message-----
> From: malcolm [mailto:malcolm@acic.co.uk]
> Sent: Tuesday, March 30, 2004 10:03 AM
> To: VRF
> Subject: [vrf] WScript.Shell and VEE
> hi
> set s = CreateObject("WScript.Shell");
> s.SendKeys("A")
> This works great in win 2k
ActiveX
> component
> any ides
> regards
> Malcolm Bint
ActiveX
> component
> any ides
> To: VRF
> hi
> s.SendKeys("A")
ActiveX
> component
> any ides
> regards
> Malcolm Bint
Lee
Lee Hudson, R&D Scientist
LumiLeds Lighting, U.S., LLC
370 West Trimble Road, MS 91ML
San Jose, CA 95131
(408) 435-5834
(408) 435-6574 FAX
lee.hudson@lumileds.com
http://www.lumileds.com <http://www.lumileds.com>
http://www.luxeon.com <http://www.luxeon.com>
From: Schlieker, Reiner [mailto:reiner.schlieker@siemens.com]
Sent: Monday, March 29, 2004 9:52 AM
Subject: [vrf] Barcode printing
Hello all,
Has anyone every printed out barcode (with plain text) labels from VEE?
What did you use to do it?
_____________________________________
Reiner Schlieker
Test Equipment Designer
Siemens Milltronics Process Instruments Inc.
Phone: (705) 740-7553
Fax: (705) 740-7692
Email: reiner.schlieker@siemens.com
Web: www.siemens-milltronics.com
You are currently subscribed to vrf as: lee.hudson@lumileds.com
