vrf VEE Serious Error
Question asked by VRFuser on Apr 2, 2004
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"><HTML><HEAD><META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=US-ASCII"><TITLE>Message</TITLE><META content="MSHTML 6.00.2800.1400" name=GENERATOR></HEAD><BODY><DIV><SPAN class=825502916-02042004><FONT face=Arial size=2>Does anyone know what would cause this type of error? VEE locks up the PC and I have to reboot the PC (pull the plug) and then reload the program. After this the program runs fine for a few weeks. I am running this in the development environment and not as an executable. I was advised by the person I inherited this program from who also inherited this program, that the PC just needs to be rebooted every time this occurs. This does not sounds like a good work around. Any ideas?</FONT></SPAN></DIV><DIV><SPAN class=825502916-02042004><FONT face=Arial size=2></FONT></SPAN> </DIV><DIV><SPAN class=825502916-02042004><FONT face=Arial size=2></FONT></SPAN> </DIV><DIV><SPAN class=825502916-02042004><FONT face=Arial size=2></FONT></SPAN> </DIV><DIV><SPAN class=825502916-02042004><FONT face=Arial size=2>Internal Error: Segmentation violation (signal = 11)</FONT></SPAN></DIV><DIV><SPAN class=825502916-02042004><FONT face=Arial size=2>Caution: The program currently loaded into VEE may have been corrupted! To save any changes to this program use a new file name. Then exit and restart VEE.</FONT></SPAN></DIV><DIV><SPAN class=825502916-02042004><FONT face=Arial size=2></FONT></SPAN> </DIV><DIV><SPAN class=825502916-02042004><FONT face=Arial size=2>VEE will not let you overwrite any existing file until you exit and restart VEE</FONT></SPAN></DIV><DIV><SPAN class=825502916-02042004><FONT face=Arial size=2></FONT></SPAN> </DIV><DIV><SPAN class=825502916-02042004><FONT face=Arial size=2>Object title: On Cycle</FONT></SPAN></DIV><DIV><SPAN class=825502916-02042004><FONT face=Arial size=2>Object type: On Cycle</FONT></SPAN></DIV><DIV><SPAN class=825502916-02042004><FONT face=Arial size=2>Error Number 979</FONT></SPAN></DIV><DIV><SPAN class=825502916-02042004><FONT face=Arial size=2></FONT></SPAN> </DIV><DIV><SPAN class=825502916-02042004><FONT face=Arial size=2>Ok Help</FONT></SPAN></DIV><DIV> </DIV><DIV align=left><FONT face=Arial size=2>Jeff Christensen <BR>IP Core Gateways <BR>Motorola, Broadband Communications Sector <BR>jeff.christensen@motorola.com <BR></FONT><A href="http://www.motorola.com/broadband"><FONT face=Arial size=2>www.motorola.com/broadband</FONT></A><FONT face=Arial size=2> </FONT></DIV><DIV> </DIV></BODY></HTML>Ø¢yË«+.n+}("&N.n+zwZnV隊[h :"XW( Ӣ칻 &Þ±iZGj)m     ^jl+j z{r:,zwfz -bf)+-隊P/Ú‚)^Ü¢`!wv  ^x%lzwZ,j 0l+j z{r
