Hi I am using Vee 6.2 and windows 2k.
When using the e4406 VSA for measuring cdma IS95.
When the Rho display is up showing the I/Q Measured Compl vector display.
I cannot find a command to download the trace data (even after reading the
programmers manual!)
Have any of you folks found the right set of commands to do this?
Any help would be great
Thanks Denis
Send your favorite VEE example to "VRF-EXAMPLES@agilent.com" for possible inclusion in VEE 7.0!
Thanks Denis
I won't pretend to know anything about your 'Rho's' and your 'compl vector
displays' but the command:
trace:data? trace1
and then read a REAL ARRAY:401 back
(for 401 data points)
it works for me!!
an annoyonce I found with this though is that Agilent allowed you to set
the number of points on the E series - but not on the L- Series - grrrr!!
Alex.
(Raytheon Systems)
UK
"Daly, Denis" To: VRF <vrf@agilent.com>
<dalyd@tycoelectronic cc:
s.com> Subject: [vrf] E4406 VSA I/Q measured compl vector trace download?
21/01/04
14:47
Please respond to "Daly, Denis"
Stationery name:-Untitled-
Thanks Denis
You are currently subscribed to vrf as: Alex.Barrett@raytheon.co.uk
