Hello again,
I have had the same need, and I accomplished it by using the Arb to create a waveform for AM, then I use the ESG marker event as the trigger to the rest of the system. In this way, the Arb fires the marker event at the start of the arb file, so the AM waveform always has the same shape relative to the trigger.
Joel
From: Henrik.Hald@nokia.com [mailto:Henrik.Hald@nokia.com]
Sent: Wednesday, January 28, 2004 8:11 AM
Subject: [vrf] ESG4438C External Trig of 'internal AM generator'
The Agilent ESG4438C RF generator has the possibility of running AM modulation (on RF).
But to insure that the AM "starts" in the same point every time I want to trig this with an external trigger.
But how ??
There are a lot of different ways to trig, waveforms etc.
But I haven't been able to find a way to trig the AM, is this really not possible
Venlig hilsen, Kind regards
Henrik Damborg Hald (C4)
Nokia Denmark A/S
Frederikskaj, DK-1790 Copenhagen V, Denmark
Phone: +45 3329 2929, fax: +45 3326 3245
Direct: +45 3329 4835, mobile: +45 2072 4682
Email: Henrik.Hald@nokia.com
You are currently subscribed to vrf as: joel_dunsmore@agilent.com
Send your favorite VEE example to "VRF-EXAMPLES@agilent.com" for possible inclusion in VEE 7.0!
Joel
But how ??
Nokia Denmark A/S
