I don't know anything about it; I've never done it, but there is a VEE
example named pid.vee under Help>examples>applications. Maybe that could
help you.
Reiner
From: amilineni rammohanchowdary [mailto:rammohanchowdary@yahoo.com]
Sent: Tuesday, December 16, 2003 10:15 AM
To: VRF
Subject: [vrf] regarding the PID control
Hello vrf,
Iam having doubts regarding the PID control use to
regulate the voltage so that the current can be varied
up and down until a stable position is acheived. this
i need to control for a milhaus card of 4670 and 1600
cards.
so for a change in the voltage there should be change
in the current until a stable point is reached.
Is pID control available with vee pro?
with regards
ram
__________________________________
Do you Yahoo!?
Protect your identity with Yahoo! Mail AddressGuard
http://antispam.yahoo.com/whatsnewfree
You are currently subscribed to vrf as: reiner.schlieker@siemens.com
help you.
Reiner
To: VRF
Hello vrf,
cards.
with regards
ram
Do you Yahoo!?
