Hello !
I need to start a VEE program from another VEE program.
Today I use the "Execute program (PC)" function.
The only way I know to remotely run the other program is to use the parameters, cmd /c vee -r followed by the filename.
This works, but it is not possible to debug the program. When the program stops it also close.
Is it possible to start another VEE program with equal degug possibilites as when a program is started by using the run button in the toolbar ??
I wish also that the program-window remains open even after the program stops.
Best regards
Bjrn Persson X (EAB)
Test system developer, WCDMA
Ericsson AB
KI/ EAB/ RWL/ VR
Tel: +46 8 764 19 59
Fax: +46 8 751 88 41
Mobile: +70 634 69 12
mailto:bjorn.k.persson@ericsson.com
Send your favorite VEE example to "VRF-EXAMPLES@agilent.com" for possible inclusion in VEE 7.0!
Best regards
Ericsson AB
KI/ EAB/ RWL/ VR
