Hi Marco,
Lets assume that your data is at the output of the from file object, say A
Get a formula box and write "A[*,i]" inside. This gives you the ith column
of 2-D array.
For your case write "A[*,1]" inside which gives 2nd column. Remember that
VEE is zero-based.
Regards
----- Original Message -----
To: "VRF" <vrf@agilent.com>
Sent: Friday, January 30, 2004 7:39 AM
Subject: [vrf] How to read an array
Hi!
I'm using Vee 5.01 and I'm reading array which includes two columns.
What is a best way to get just the another column from the array? The
file I'm reading is in .txt format.
Marco.
__
Sano ei kuukausimaksuille. Hanki Suomen ainoa aidosti
kuukausimaksuton GSM-liittym osoitteesta http://www.saunalahti.fi
You are currently subscribed to vrf as: ceken@mst.aselsan.com.tr
Send your favorite VEE example to "VRF-EXAMPLES@agilent.com" for possible
inclusion in VEE 7.0!
Send your favorite VEE example to "VRF-EXAMPLES@agilent.com" for possible inclusion in VEE 7.0!
of 2-D array.
VEE is zero-based.
Regards
Hi!
Marco.
__
