vrf Excel Range(X).Select error
Question asked by fukui.yutaka on Mar 22, 2004
I'm not sure wheather this hint solves this error or not.
But, how about replacing "ExcelApp.....Range(B).Select" by
"ExcelApp.....Range(B:B).Select".
> hermann.ruckerbauer@infineon.com wrote:
> Hello, maye somebody can give me a hint ...
> We do have some ActiveX funtion to access data in Excel and we are
> getting some kind of random error just selecting a Cell.
> We are giving the command "ExcelApp.....Range(B).Select" and most of
> the time this is working fine. But sometimes we are
> getting an error like "The Select porperty of Range object could not
> be assigned"  (free translated from german).
> I can post the exact error message if this helps (need to transfer it
> first from a standalone pc)
> Before this Command we are making a screenshot on a scope, and
> transferred this .png file via GPIB. So this is the first ActiveX
> comand
> after some kind of other commands. And as I mentioned already we do
> not get a reproducable error. Sometimes this runs
> 10 times without problems, sometimes the error message pops up every
> second run.
> Thanks for every hint ...
> Hermann
> You are currently subscribed to vrf as: fukui.yutaka@jp.fujitsu.com
*  $BJ!0f!!K-!J (BFUKUI Yutaka)
* E-Mail: fukui.yutaka@jp.fujitsu.com
*  $BIY;NDL3t<02q<R!!@n:j9)>l (B
*  $B$b$N$E$/$j?d?JKIt!&@8;:5;=Q3+H/E}3gIt!K7WB,@_Hw3+H/It (B
*  $B7WB,@_Hw3+H/It (BHomePage http://www.psl.fujitsu.co.jp/htd2/ksk/
*  $B@n:j;TCf866h>e>.EDCf#4 (B- $B#1 (B- $B#1!!M9JXHV9f!' (B211-8588
* TEL  $B!!30@~ (B 044-754-3657, $B!!Fb@~ (B 711-3-1966,7
* FAX  $B!!30@~ (B 044-754-3509, $B!!Fb@~ (B 711-3-5359
