Thanks everyone for the advice on this.
Barrie's comments seem the best solution for me (i.e. make the instruments
'Not live'). It just seems a pity that the io.config setup is not embedded
within the main .vee / .vxe file.
I agree that RS232 com ports on PC's will be a thing of the past soon but
at least the USB-serial converters have come right down in price. I was
going to develop the hardware myself for our ' Microchip PIC16F877' module.
That was, before I found the converters (Prolific) for 5 pounds each. I
could not even buy the parts for that price.
thanks again,
Ashley
thanks again,
Ashley
If you don't have the IO manual, go to the link below and select the IO
Libraries Installation and Configuration Guide for Windows.
http://we.home.agilent.com/cgi-bin/bvpub/agilent/editorial/cp_MiscEditorial.
jsp?NAV_ID=-12363.536883372.02&LANGUAGE_CODE=eng&CONTENT_KEY=1000002419%3aep
sg%3aman&ID=1000002419%3aepsg%3aman&COUNTRY_CODE=US
Thank You
Cecil L. Gray
Engineering Technician II
1 Holmes Way
Building B
Milford Ma.01757
cgray@holmeshq.com
508-422-1497
Sent: Monday, March 29, 2004 11:15 AM
To: VRF
Cc: VRF
Subject: [vrf] Re: RS232 Instuments config
Ashley,
Use Vee IO (Agilent IO Libraries Control) to establish all the ports you
need and designate those you don't actually have on your machine as "Not
Live". This should allow you to load the program for editing. What a
pain!!! Version 6 helps with this but doesn't solve all the problems.
Barrie
You are currently subscribed to vrf as: cgray@holmeshq.com
