Hi Rufus,
please, let others live with their opinion - it's only a tool, not a
religion!
We must face the reality: there is nothing really new or exciting within
.NET, but we can't blame Agilent for that. Some day, when they have bought
Microsoft, we can squeeze some really different concepts out of them ))
Personally, I would like to see VEE on top of a realtime OS - that would
alter a lot of things in one shot - and cause a lot of new pain, too.
Best regards,
Stefan
Rufus Warren schrieb:
> Hold your tongue, seems VEE 7 is a great tool for the windows environment
> now that .NET is included, this allows capability of most all well behaved
> windows program. So take some time and review .NET. Instead of just the
> .NET engine see MS VISUAL STUDIO at
> http://msdn.microsoft.com/library/defau ... sintro/htm
> l/vxovrvisualstudioenterpriseeditionfeatures.asp ; so what else do you want?
> _____
> From: Martn Castillejos, Juan Carlos [mailto:jcmartin@indra.es]
> Sent: Tuesday, March 23, 2004 9:51 AM
> To: VRF
> Subject: [vrf] RE: .NET in VEE7
> -----Mensaje original-----
> De: Losik, Vlad [mailto:losikv@tycoelectronics.com]
> Enviado el: martes, 23 de marzo de 2004 15:12
> Para: VRF
> Asunto: [vrf] .NET in VEE7
> Hello VRF users.
> Perhaps I am the only one who does not share enthusiasm about new release of
> VEE 7 ?
> Probably you expected more about new VEE version, or other type of
> enhacements.
> But I have to express my deep disappointment with long awaiting NEW version
> of VEE.
> There are almost no new features in VEE7 (except for editor enhancements).
> I don't agree with you. There are more enhacements apart of Notepad:
> - "Do" and "undo" in most part of VEE.
> - You can configure several objects into a panel at the same time, by colour
> or by size, for example.
> - You can set in front or in back one object overlaped with other in the
> panel.
> - You can use direct communication through an USB or LAN equipment by using
> last SICL
> Sure .NET is great but it will not add new user interface capabilities, it
> will not add menus
> or ability to programmatically set front panel object properties. Nor will
> it add event handling mechanism.
> I think you can use .NET and generate other menus to access programatically.
> You can access to Windows resources. I think it would be possible to work
> with event handling mechanism, although it is not easy.
> Yes , you can use some perks from .NET like file selection dialog but it
> require installation of about 200MB of .Net runtime.
> Currenty with hard disk of 80GB, what is the problem in 200 additional MB?
> What is the size of W95 (or even 2000) in comparation of XP?
> Is it really a progress? As far as I can tell there is nothing in the .NET
> that could not be done before with few lines of VB code compiled into
> Probably you could do the same, but not so easy and fast.
> Active X dll or ocx. I think Agilent needs to extend core VEE language, not
> to promote latest Microsoft technology.
> I agree that VEE could be improved in some other areas, but that does not
> mean that this 7.0 is a new release and it is not a possible 6.3.
> After all if you want to program in .NET get Visual Studio.
> Sorry for my pessimism but I could not help to stick my 5 cents.
> I would like more other possible improvements than VEE 7.0 provides but I
> think VEE 7.0 is better than old 6.x version. Not all is good, not all is
> bad, that it's life. The only I hope is that next version 7.1 could include
> some more things related you (and probably I) wanted.
> Regards
> You are currently subscribed to vrf as: jcmartin@indra.es
> Este correo electrnico y, en su caso, cualquier fichero anexo al mismo,
> contiene informacin de carcter confidencial exclusivamente dirigida a su
> destinatario o destinatarios. Queda prohibida su divulgacin, copia o
> distribucin a terceros sin la previa autorizacin escrita de Indra. En el
> caso de haber recibido este correo electrnico por error, se ruega notificar
> inmediatamente esta circunstancia mediante reenvo a la direccin
> electrnica del remitente.
> The information in this e-mail and in any attachments is confidential and
> solely for the attention and use of the named addressee(s). You are hereby
> notified that any dissemination, distribution or copy of this communication
> is prohibited without the prior written consent of Indra. If you have
> received this communication in error, please, notify the sender by reply
> e-mail ---
> You are currently subscribed to vrf as: rwarren@amti.net
> You are currently subscribed to vrf as: stefan.paulick@urbeli.com
> If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".
religion!
Best regards,
Stefan
> _____
> To: VRF
> Para: VRF
> Hello VRF users.
> VEE 7 ?
> enhacements.
> of VEE.
> panel.
> last SICL
> will not add menus
> Regards
> e-mail ---
<b><span style='font-weight:bold'>From:</span></b> Losik, Vlad
<b><span style='font-weight:bold'>Sent:</span></b> Tuesday, March 23, 200411:39 AM
<b><span style='font-weight:bold'>To:</span></b> 'Rufus Warren'
<b><span style='font-weight:bold'>Subject:</span></b> RE: [vrf] RE: .NET inVEE7</span></font></p><p class=MsoNormal><font size=3 face="Times New Roman"><span style='font-size:12.0pt'> </span></font></p><p class=MsoNormal><font size=2 color=navy face=Arial><span style='font-size:10.0pt;font-family:Arial;color:navy'>What I want ?</span></font></p><p class=MsoNormal><font size=2 color=navy face=Arial><span style='font-size:10.0pt;font-family:Arial;color:navy'>How about drop down menu on functionpanel?</span></font></p><p class=MsoNormal><font size=2 color=navy face=Arial><span style='font-size:10.0pt;font-family:Arial;color:navy'>Or expression like this in formula object:Graph1.Visible=False;</span></font></p><p class=MsoNormal><font size=2 color=navy face=Arial><span style='font-size:10.0pt;font-family:Arial;color:navy'>Is .Net going to help with it?</span></font></p><p class=MsoNormal><font size=2 color=navy face=Arial><span style='font-size:10.0pt;font-family:Arial;color:navy'>I don't think so.</span></font></p><p class=MsoNormal><font size=2 color=navy face=Arial><span style='font-size:10.0pt;font-family:Arial;color:navy'> </span></font></p><p class=MsoNormal style='margin-left:.5in'><font size=2 face=Tahoma><spanstyle='font-size:10.0pt;font-family:Tahoma'>-----Original Message-----
<b><span style='font-weight:bold'>From:</span></b> Rufus Warren[mailto:rwarren@amti.net]
<b><span style='font-weight:bold'>Sent:</span></b> Tuesday, March 23, 200410:18 AM
<b><span style='font-weight:bold'>To:</span></b> VRF
<b><span style='font-weight:bold'>Subject:</span></b> [vrf] RE: .NET in VEE7</span></font></p><p class=MsoNormal style='margin-left:.5in'><font size=3 face="Times New Roman"><spanstyle='font-size:12.0pt'> </span></font></p><p class=MsoNormal style='margin-left:.5in'><font size=2 color=blue face=Arial><spanstyle='font-size:10.0pt;font-family:Arial;color:blue'>Hold your tongue, seemsVEE 7 is a great tool for the windows environment now that .NET is included,this allows capability of most all well behaved windows program. So takesome time and review .NET. Instead of just the .NET engine see MS VISUALSTUDIO at <ahref="http://msdn.microsoft.com/library/default.asp?url=/library/en-us/vsintro/html/vxovrvisualstudioenterpriseeditionfeatures.asp">http://msdn.microsoft.com/library/default.asp?url=/library/en-us/vsintro/html/vxovrvisualstudioenterpriseeditionfeatures.asp</a> ;so what else do you want?</span></font></p><p class=MsoNormal style='margin-left:.5in'><font size=3 face="Times New Roman"><spanstyle='font-size:12.0pt'> </span></font></p><div style='margin-left:.5in'><div class=MsoNormal align=center style='text-align:center'><font size=3face="Times New Roman"><span style='font-size:12.0pt'><hr size=2 width="100%" align=center></span></font></div></div><p class=MsoNormal style='margin-right:0in;margin-bottom:12.0pt;margin-left:.5in'><b><font size=2 face=Tahoma><span style='font-size:10.0pt;font-family:Tahoma;font-weight:bold'>From:</span></font></b><font size=2 face=Tahoma><spanstyle='font-size:10.0pt;font-family:Tahoma'> Martn Castillejos, Juan Carlos[mailto:jcmartin@indra.es]
<b><span style='font-weight:bold'>Sent:</span></b> Tuesday, March 23, 2004 9:51AM
<b><span style='font-weight:bold'>Subject:</span></b> [vrf] RE: .NET in VEE7</span></font></p><blockquote style='border:none;border-left:solid blue 1.5pt;padding:0in 0in 0in 4.0pt;margin-left:3.75pt;margin-top:5.0pt;margin-bottom:5.0pt'><p class=MsoNormal style='margin-right:0in;margin-bottom:12.0pt;margin-left:.5in'><font size=2 face=Tahoma><span style='font-size:10.0pt;font-family:Tahoma'>-----Mensajeoriginal-----
<b><span style='font-weight:bold'>De:</span></b> Losik, Vlad[mailto:losikv@tycoelectronics.com]
<b><span style='font-weight:bold'>Enviado el:</span></b> martes, 23 de marzo de2004 15:12
<b><span style='font-weight:bold'>Para:</span></b> VRF
<b><span style='font-weight:bold'>Asunto:</span></b> [vrf] .NET in VEE7</span></font></p><p style='margin-left:.5in'><font size=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'>Hello VRF users.</span></font></p><p style='margin-left:.5in'><font size=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'>Perhaps I am the only one who does not shareenthusiasm about new release of VEE 7 ?</span></font><font size=2 color=blueface=Verdana><span style='font-size:10.0pt;font-family:Verdana;color:blue'> </span></font></p></blockquote><p class=MsoNormal style='margin-left:.5in'><font size=2 color=blueface=Verdana><span style='font-size:10.0pt;font-family:Verdana;color:blue'>Probablyyou expected more about new VEE version, or other type ofenhacements. </span></font></p><blockquote style='border:none;border-left:solid blue 1.5pt;padding:0in 0in 0in 4.0pt;margin-left:3.75pt;margin-top:5.0pt;margin-bottom:5.0pt'><p style='margin-left:.5in'><font size=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'>But I have to express my deep</span></font> <fontsize=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'>disappointmentwith long awaiting</span></font> <font size=2 face=Arial><spanstyle='font-size:10.0pt;font-family:Arial'>NEW version of VEE.</span></font></p><p style='margin-left:.5in'><font size=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'>There are almost no new features in VEE7</span></font><font size=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'>(except</span></font><font size=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'>for</span></font><font size=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'>editor</span></font><font size=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'>enhancements).</span></font><fontsize=2 color=blue face=Verdana><span style='font-size:10.0pt;font-family:Verdana;color:blue'> </span></font></p></blockquote><p class=MsoNormal style='margin-left:.5in'><font size=2 color=blueface=Verdana><span style='font-size:10.0pt;font-family:Verdana;color:blue'>I don'tagree with you. There are more enhacements apart of Notepad:</span></font></p><p class=MsoNormal style='margin-left:.5in'><font size=2 color=blueface=Verdana><span style='font-size:10.0pt;font-family:Verdana;color:blue'>-"Do" and "undo" in most part of VEE.</span></font></p><p class=MsoNormal style='margin-left:.5in'><font size=2 color=blueface=Verdana><span style='font-size:10.0pt;font-family:Verdana;color:blue'>-You can configure several objects into a panel at the same time, by colour orby size, for example.</span></font></p><p class=MsoNormal style='margin-left:.5in'><font size=2 color=blueface=Verdana><span style='font-size:10.0pt;font-family:Verdana;color:blue'>-You can set in front or in back one object overlaped with other in the panel.</span></font></p><p class=MsoNormal style='margin-left:.5in'><font size=2 color=blueface=Verdana><span style='font-size:10.0pt;font-family:Verdana;color:blue'>-You can use direct communication through an USB or LAN equipment by using lastSICL</span></font></p><p class=MsoNormal style='margin-left:.5in'><font size=2 color=blueface=Verdana><span style='font-size:10.0pt;font-family:Verdana;color:blue'>.....</span></font></p><p class=MsoNormal style='margin-left:.5in'><font size=3 face="Times New Roman"><spanstyle='font-size:12.0pt'> </span></font></p><blockquote style='border:none;border-left:solid blue 1.5pt;padding:0in 0in 0in 4.0pt;margin-left:3.75pt;margin-top:5.0pt;margin-bottom:5.0pt'><p style='margin-left:.5in'><font size=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'>Sure .NET is great but it will not add new userinterface capabilities, it will not add menus </span></font></p><p style='margin-left:.5in'><font size=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'>or ability to programmatically set front panel objectproperties. Nor will it add event handling</span></font> <font size=2face=Arial><span style='font-size:10.0pt;font-family:Arial'>mechanism.</span></font><fontsize=2 color=blue face=Verdana><span style='font-size:10.0pt;font-family:Verdana;color:blue'> </span></font></p></blockquote><p class=MsoNormal style='margin-left:.5in'><font size=2 color=blueface=Verdana><span style='font-size:10.0pt;font-family:Verdana;color:blue'>Ithink you can use .NET and generate other menus to accessprogramatically. You can access to Windows resources. I think it would be possibleto work with event handling mechanism, although it is not easy.</span></font></p><p class=MsoNormal style='margin-left:.5in'><font size=3 face="Times New Roman"><spanstyle='font-size:12.0pt'> </span></font></p><blockquote style='border:none;border-left:solid blue 1.5pt;padding:0in 0in 0in 4.0pt;margin-left:3.75pt;margin-top:5.0pt;margin-bottom:5.0pt'><p style='margin-left:.5in'><font size=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'>Yes , you can use some perks from .NET likefile selection dialog but it</span></font> <font size=2 face=Arial><spanstyle='font-size:10.0pt;font-family:Arial'>require</span></font> <font size=2face=Arial><span style='font-size:10.0pt;font-family:Arial'>installation ofabout 200MB of .Net runtime.</span></font><font size=2 color=blue face=Verdana><spanstyle='font-size:10.0pt;font-family:Verdana;color:blue'> </span></font></p></blockquote><p class=MsoNormal style='margin-left:.5in'><font size=2 color=blueface=Verdana><span style='font-size:10.0pt;font-family:Verdana;color:blue'>Currentywith hard disk of 80GB, what is the problem in 200 additional MB? What is thesize of W95 (or even 2000) in comparation of XP? </span></font></p><blockquote style='border:none;border-left:solid blue 1.5pt;padding:0in 0in 0in 4.0pt;margin-left:3.75pt;margin-top:5.0pt;margin-bottom:5.0pt'><p style='margin-left:.5in'><font size=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'>Is it really a progress? As far as I can tell thereis nothing in the .NET that could not be done before with few lines of VB codecompiled into</span></font><font size=2 color=blue face=Verdana><spanstyle='font-size:10.0pt;font-family:Verdana;color:blue'> </span></font></p></blockquote><p class=MsoNormal style='margin-left:.5in'><font size=2 color=blueface=Verdana><span style='font-size:10.0pt;font-family:Verdana;color:blue'>Probablyyou could do the same, but not so easy and fast. </span></font></p><blockquote style='border:none;border-left:solid blue 1.5pt;padding:0in 0in 0in 4.0pt;margin-left:3.75pt;margin-top:5.0pt;margin-bottom:5.0pt'><p style='margin-left:.5in'><font size=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'>Active X dll or ocx. I think Agilent needs to extendcore VEE</span></font> <font size=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'>language, not</span></font> <font size=2 face=Arial><spanstyle='font-size:10.0pt;font-family:Arial'>to</span></font> <font size=2face=Arial><span style='font-size:10.0pt;font-family:Arial'>promote</span></font><font size=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'>latestMicrosoft technology.</span></font><font size=2 color=blue face=Verdana><spanstyle='font-size:10.0pt;font-family:Verdana;color:blue'> </span></font></p></blockquote><p class=MsoNormal style='margin-left:.5in'><font size=2 color=blueface=Verdana><span style='font-size:10.0pt;font-family:Verdana;color:blue'>Iagree that VEE could be improved in some other areas, but that doesnot mean that this 7.0 is a new release and it is not apossible 6.3.</span></font></p><blockquote style='border:none;border-left:solid blue 1.5pt;padding:0in 0in 0in 4.0pt;margin-left:3.75pt;margin-top:5.0pt;margin-bottom:5.0pt'><p style='margin-left:.5in'><font size=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'>After all if you want to program in .NET get VisualStudio.</span></font></p><p style='margin-left:.5in'><font size=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'>Sorry for my</span></font> <font size=2 face=Arial><spanstyle='font-size:10.0pt;font-family:Arial'>pessimism but I could not help tostick my 5 cents.</span></font><font size=2 color=blue face=Verdana><spanstyle='font-size:10.0pt;font-family:Verdana;color:blue'> </span></font></p></blockquote><p class=MsoNormal style='margin-left:.5in'><font size=2 color=blueface=Verdana><span style='font-size:10.0pt;font-family:Verdana;color:blue'>I wouldlike more other possible improvements than VEE 7.0 provides but I thinkVEE 7.0 is better than old 6.x version. Not all is good, not all is bad, thatit's life. The only I hope is that next version 7.1 could include somemore things related you (and probably I) wanted.</span></font></p><p class=MsoNormal style='margin-left:.5in'><font size=3 face="Times New Roman"><spanstyle='font-size:12.0pt'> </span></font></p><p class=MsoNormal style='margin-left:.5in'><font size=2 color=blueface=Verdana><span style='font-size:10.0pt;font-family:Verdana;color:blue'>Regards </span></font></p><blockquote style='border:none;border-left:solid blue 1.5pt;padding:0in 0in 0in 4.0pt;margin-left:3.75pt;margin-top:5.0pt;margin-bottom:5.0pt'><p class=MsoNormal style='margin-left:.5in'><font size=3 face="Times New Roman"><spanstyle='font-size:12.0pt'>---
To subscribe send a blank email to"join-vrf@it.lists.it.agilent.com".
To unsubscribe send a blank email to"leave-vrf@it.lists.it.agilent.com".
If you need help with the mailing list send a message to"owner-vrf@it.lists.it.agilent.com". </span></font></p></blockquote><p class=MsoNormal style='margin-left:.5in'><font size=3 face="Times New Roman"><spanstyle='font-size:12.0pt'>-------------------------------------------------------------------------------------------------------------------
Este correo electrnico y, en su caso, cualquier fichero anexo al mismo,contiene informacin de carcter confidencial exclusivamente dirigida a sudestinatario o destinatarios. Queda prohibida su divulgacin, copia odistribucin a terceros sin la previa autorizacin escrita de Indra. En el casode haber recibido este correo electrnico por error, se ruega notificarinmediatamente esta circunstancia mediante reenvo a la direccin electrnicadel remitente.
The information in this e-mail and in any attachments is confidential andsolely for the attention and use of the named addressee(s). You are herebynotified that any dissemination, distribution or copy of this communication isprohibited without the prior written consent of Indra. If you have receivedthis communication in error, please, notify the sender by reply e-mail ---
If you need help with the mailing list send a message to"owner-vrf@it.lists.it.agilent.com". ---
You are currently subscribed to vrf as: losikv@tycoelectronics.com
If you need help with the mailing list send a message to"owner-vrf@it.lists.it.agilent.com". </span></font></p></div>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</BODY></html>
I'd like to see Agilent concentrating effort on extending core of the Vee
as a Programming Language rather than just accommodating new features of
OS.
From: Stefan Paulick [mailto:stefan.paulick@urbeli.com]
Sent: Tuesday, March 23, 2004 12:22 PM
To: VRF
Cc: VRF
Subject: [vrf] Re: .NET in VEE7
Hi Rufus,
religion!
Best regards,
Stefan
want?
> _____
> To: VRF
> Para: VRF
> Hello VRF users.
of
> VEE 7 ?
> enhacements.
version
> of VEE.
colour
> panel.
using
> last SICL
> will not add menus
programatically.
not
include
> Regards
notificar
communication
> e-mail ---
I really did not mean any bad disposition. Just looking at the magnitude of
code within .NET makes the whole question mute. I suppose it would have
been nice if AGILENT had given us an easy way to build our own menus, but I
guess we can always build our own set of objects. So my response was to
that end.
ru
To: VRF
Cc: VRF
Hi Rufus,
religion!
Best regards,
Stefan
> environment now that .NET is included, this allows capability of most
> all well behaved windows program. So take some time and review .NET.
> Instead of just the .NET engine see MS VISUAL STUDIO at
> http://msdn.microsoft.com/library/defau ... n-us/vsint
> ro/htm l/vxovrvisualstudioenterpriseeditionfeatures.asp ; so what else
> do you want?
> _____
> To: VRF
> Para: VRF
> Hello VRF users.
> release of VEE 7 ?
> enhacements.
> version of VEE.
> colour or by size, for example.
> the panel.
> using last SICL .....
> will it add event handling mechanism.
programatically.
> it require installation of about 200MB of .Net runtime.
> .NET that could not be done before with few lines of VB code compiled
> into
> language, not to promote latest Microsoft technology.
> not mean that this 7.0 is a new release and it is not a possible 6.3.
> but I think VEE 7.0 is better than old 6.x version. Not all is good,
> not all is bad, that it's life. The only I hope is that next version
> 7.1 could include some more things related you (and probably I) wanted.
> Regards
> You are currently subscribed to vrf as: jcmartin@indra.es To subscribe
> mismo, contiene informacin de carcter confidencial exclusivamente
> dirigida a su destinatario o destinatarios. Queda prohibida su
> divulgacin, copia o distribucin a terceros sin la previa
> autorizacin escrita de Indra. En el caso de haber recibido este
> correo electrnico por error, se ruega notificar inmediatamente esta
> circunstancia mediante reenvo a la direccin electrnica del remitente.
> and solely for the attention and use of the named addressee(s). You
> are hereby notified that any dissemination, distribution or copy of
> this communication is prohibited without the prior written consent of
> Indra. If you have received this communication in error, please,
> notify the sender by reply e-mail --- You are currently subscribed to
> vrf as: rwarren@amti.net To subscribe send a blank email to
> You are currently subscribed to vrf as: stefan.paulick@urbeli.com To
You are currently subscribed to vrf as: rwarren@amti.net To subscribe send a
Este correo electrnico y, en su caso, cualquier fichero anexo al mismo, contiene informacin de carcter confidencial exclusivamente dirigida a su destinatario o destinatarios. Queda prohibida su divulgacin, copia o distribucin a terceros sin la previa autorizacin escrita de Indra. En el caso de haber recibido este correo electrnico por error, se ruega notificar inmediatamente esta circunstancia mediante reenvo a la direccin electrnica del remitente.
The information in this e-mail and in any attachments is confidential and solely for the attention and use of the named addressee(s). You are hereby notified that any dissemination, distribution or copy of this communication is prohibited without the prior written consent of Indra. If you have received this communication in error, please, notify the sender by reply e-mail---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</BODY></HTML>
