vrf Office version (activeX) HELP!
Question asked by scubaman on Feb 20, 2004
Ah, of course...  thanks!!!
Rich
Richard Kleinhenz
Wafer Engineering
845-892-2617
scubaman@us.ibm.com
             "Carnahan, Lyle"
             <carnahal@tycoele
             ctronics.com>                                              To
                                       VRF <vrf@agilent.com>
             02/20/2004 05:18                                           cc
             PM
        Subject
                                       [vrf] Re: Office version (activeX)
             Please respond to         HELP!
             "Carnahan, Lyle"
The following code will return the version of Excel.
set excelApp = createobject("Excel.Application");
excelApp.Version
On my system it returns 9.0.
Lyle Carnahan
Aerospace and Defense Business Unit
M/A-COM  Inc.
1011 Pawtucket Boulevard
Lowell, MA  01853-3295
Phone: (978) 442-4504
Fax:   (978) 442-4520
carnahal@tycoelectronics.com
From: Richard Kleinhenz [mailto:scubaman@us.ibm.com]
Sent: Friday, February 20, 2004 2:42 PM
To: VRF
Subject: [vrf] Re: Office version (activeX) HELP!
I have not had a response, maybe the question was unclear.
I use Vee 6.2.  The activeX automation example Word97DataSheet.vee does not
work properly with Office XP, because the FOUND parameter has the opposite
polarity compared to previous versions of office.  Ain't that grand???
Anyway, I use a similar function, and would like my program to check with
activeX object library is installed.  If 10.0, I need it to invert the
FOUND parameter.  But how do I find out programmatically what version is
installed?
Rich
Richard Kleinhenz
Wafer Engineering
845-892-2617
scubaman@us.ibm.com
             Richard
             Kleinhenz/Fishkil
             l/IBM@IBMUS                                                To
             02/19/2004 02:48                                           cc
             PM
        Subject
                                       [vrf] Office version (activeX)
             Please respond to
             Richard Kleinhenz
I have an activeX function that behaves differently with office 2000 and
office XP.  How can I find out (programmatically) which version is
installed on a machine so I can set an appropriate switch?
Rich
Richard Kleinhenz
Wafer Engineering
845-892-2617
scubaman@us.ibm.com
You are currently subscribed to vrf as: scubaman@us.ibm.com
Send your favorite VEE example to "VRF-EXAMPLES@agilent.com" for possible
inclusion in VEE 7.0!
You are currently subscribed to vrf as: carnahal@tycoelectronics.com
Send your favorite VEE example to "VRF-EXAMPLES@agilent.com" for possible inclusion in VEE 7.0!
