Hi vrf.
I want to generate a test rapport in LaTeX, which must include some graphs
from a y-plot object.
As latex only want to work with *.eps files i have to somehow save the image
in eps format.
putting a plot pin on the y-trace and setting the printer to print to file
solves this.
But when i want to do this automatically the "file output name" dialog box
appears. Is there any way to programmaticaly set the filename, so the file
name dialog does not appear ?
Sys: vee 6.01, win 2K
Any help will be strongly appreciated
Regards
Henrik R Jakobsen
_________________________________________________________________
F alle de nye og sjove ikoner med MSN Messenger http://messenger.msn.dk
Send your favorite VEE example to "VRF-EXAMPLES@agilent.com" for possible inclusion in VEE 7.0!
in eps format.
solves this.
Regards
Henrik R Jakobsen
