Hi Detlef and vrf-ers,
This is very cool!! I hadn't thought about building forms on the fly with .NET. Doing the set Var = CreateInstance() is important for this because it lets you interact with the control later on through the Var (like the Public does for my VB .NET example).
Though of course adding non-VEE code that responds to the controls (handlers) will probably be difficult without compiling some VB or C#.
Right now, it looks like you should be able to "poll" and set control states for a similar level of interaction as the example I posted. Not pretty, but may be useful in some cases.
Best Regards,
Scott Bayes
Software Technical Support
Agilent Technologies, Inc.
815 14th Street S.W.
Loveland, CO, U.S.A. 80537
970 679 3799 Tel
970 635 6867 Fax
> -----Original Message-----
> From: Baranski, Detlef [mailto:Detlef.Baranski@PILKINGTON.de]
> Sent: Tuesday, April 27, 2004 5:11 AM
> To: PDL-LISTS,VRF (A-Lists,unix1)
> Subject: [vrf] RE:using .net system.windows.forms in Vee 7.0
> Here are 2 V7-samples about playing with forms.
> There is no interaction possible, but maybe in helps in
> simulating "real
> windows feeling ".
> It is not ready yet ...
> best regards,
> detlef
> This message and any attachments are confidential, for the
> exclusive use of
> the addressee and may be legally privileged. Any other
> distribution, use or
> reproduction is unauthorised and prohibited. If you have received this
> message in error, please notify the sender immediately and delete the
> message from your system.
> Visit our internet site at http://www.pilkington.com
Best Regards,
Scott Bayes
970 679 3799 Tel
970 635 6867 Fax
> simulating "real
> windows feeling ".
> best regards,
> detlef
> exclusive use of
If your admins let you DL ZIP files from the 'net, then get them here...
http://s91320491.onlinehome.us/vrf/Interacting_with_.NET_applications.zip
http://s91320491.onlinehome.us/vrf/email_with_attachments.zip
I'll leave them up for a few weeks, so you can DL them at home if needs be.
Cheers!
Mike Groves
"BAYES,SCOTT (A-Loveland,ex1)" <scott_bayes@agilent.com> wrote:
> Does anyone have advice on ways to do this?
> I guess I could try adding a .txt suffix after or instead of the .zip, but
> that might not work and I'd probably be lynched by a screaming horde of system
> administrators.
> administrators.
Correct- you'd be lynched and it probably wouldn't work for many users.
Just uuencode the zip file and include as message text.
Stan
Above and beyond...
Now to see why Comcast won't let me edit my own web pages.
Best Regards,
Scott Bayes
970 679 3799 Tel
970 635 6867 Fax
> From: Mike Groves [mailto:mikegroves@pacbell.net]
> Sent: Monday, April 26, 2004 5:32 PM
> Dear VRF'ers with squeeky tight admins,
> them here...
> http://s91320491.onlinehome.us/vrf/Inte ... .NET_appli
> cations.zip
> http://s91320491.onlinehome.us/vrf/emai ... hments.zip
> home if needs be.
> Cheers!
> Mike Groves
> of the .zip, but
> > administrators.
> You are currently subscribed to vrf as: scott_bayes@agilent.com
Scott, are your web pages hosted locally, that is served from a
machine that's posing as a web server where you live? Or one that
lives somewhere inside Comcast's domains? The reasons are endless, and
confusing.
Gregg C Levine hansolofalcon@worldnet.att.net
"The Force will be with you...Always." Obi-Wan Kenobi
"Use the Force, Luke." Obi-Wan Kenobi
> From: BAYES,SCOTT (A-Loveland,ex1) [mailto:scott_bayes@agilent.com]
> Sent: Tuesday, April 27, 2004 1:38 PM
> To: VRF
> Cc: PDL-LISTS,VRF (A-Lists,unix1)
> Wow, thanks Mike!
> Above and beyond...
> Best Regards,
> Scott Bayes
> 970 679 3799 Tel
> 970 635 6867 Fax
> > them here...
> > cations.zip
> > home if needs be.
> > Cheers!
> > Mike Groves
> > of the .zip, but
> > > administrators.
